MPC5744P SPI 32bit/frame SPI_PAL
838927242
I  transmit 16bit/frame SPI  with SPI_PAL ,no problem heppend;
but when I try to transmit 32bit/frame SPI  the initialization can not pass.
who can help solve the problem.... thanks
razva_tilimpea
On this CPU are supports native maximum 16 bits frame.
You can workaround this by using continuous mode to keep SS low during 2 frames of 16 bits.
Razvan
