i.mx8m mini evk as a wireless client and WAP
Question asked by Jeff Freeman on Aug 18, 2019
Latest reply on Aug 19, 2019 by Jeff Freeman
I would like to be able to have i.mx8m mini evk access wifi router and act as hotspot using hostapd simultaneously.
I am using ubuntu-18.04.2.
Here are the steps I took:
  1. Followed https://community.nxp.com/message/1125263 to enable wifi
  2. Followed these steps to setup WAP
    1. Installed hostapd
    2. Update /etc/hostapd.conf with the following:
auth_algs=1
channel=6
hw_mode=g
ieee80211n=1
ignore_broadcast_ssid=0
interface=wlan0
wpa=2
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
driver=nl80211
ssid=<name>
wpa_passphrase=<passphrase>
I then tested WAP by doing "sudo /usr/sbin/hostapd /etc/hostapd.conf &”
Each of these work individually but not together (obviously). I believe I need to use dnsmasq and iptables to masquerade virtual interface, but this is quickly getting over my head. Can someone assist?
Jeff
