Can not burn Linux prebuilt image to iMX 8M Mini EVK with uuu
Question asked by Hongbo Liu on Aug 15, 2019
Latest reply on Mar 28, 2020 by Francesco Castelli
Hi NXP Community team,
I got an iMX 8M Mini EVK board, I was trying to burn Linux prebuilt images to MicroSD card, it always fails.
Images I tried are L4.14.78_1.0.0_ga_images_MX8MMEVK.zip and L4.14.98_2.0.0_ga_images_MX8MMEVK.zip.
Host Linux is Debian 10.0.
uuu is built from ttps://github.com/NXPmicro/mfgtools.git.
Switches on board set to SD Mode: 1010xxxxxx xxxxxxxxx0, 16G MicroSD card inserted.
Ran following command on Host Linux
uuu L4.14.78_1.0.0_ga_images_MX8MMEVK.zip
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.3.34-8-g8bb3f01
Success 0 Failure 0
1:2 1/ 1 [=================100%=================] SDP: boot -f imx-boot-imx8mmevk-sd.bin-flash_evk
It hangs there forever.
Could you tell me anything I did wrong and what else I can try?
And the error messages on USB debug console (continuously if useing L4.14.98_2.0.0_ga_images_MX8MMEVK.zip):
U-Boot SPL 2018.03-imx_v2018.03_4.14.78_1.0.0_ga+g654088c (Nov 28 2018 - 19:15:55 +0000)
power_bd71837_init
DDRINFO: start lpddr4 ddr init
DRAM PHY training for 3000MTS
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training FAILED
Training FAILED
DRAM PHY training for 400MTS
Training FAILED
DRAM PHY training for 100MTS
Training FAILED
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from USB SDP
"Synchronous Abort" handler, esr 0x96000000
elr: 00000000007e595c lr : 00000000007e58b4
x0 : 05081c63c21b0000 x1 : 05081c637ffaf011
x2 : 0000000042200010 x3 : 00000000007f5f30
x4 : 00000000007f5f20 x5 : fffffffffffffff8
x6 : 0000000000000000 x7 : 000000000091de38
x8 : 000000000091dc40 x9 : 0000000000000002
x10: 00000000ffffffd0 x11: 0000000000000006
x12: 000000000001869f x13: 0000000000000008
x14: 000000000090e558 x15: 00000000ffffffff
x16: 0000000000000000 x17: 0000000000000005
x18: 000000000091de40 x19: 0000000000000ff0
x20: 0000000000001000 x21: 0000000042200ff0
x22: 0000000000000310 x23: 0000000000000300
x24: 00000000007f0bef x25: 00000000007f7000
x26: 00000000deadbeef x27: 0000000000000000
x28: 0000000000000000 x29: 000000000091dca0
Resetting CPU ...
resetting ...
power_bd71837_init
Training FAILED
Training FAILED
Training FAILED
Training FAILED
Normal Boot
g_dnl_register: failed!, error: -12
SDP: initialize...
