In MCUXpresso Config Too, I seem to have lost the 'Clocks' tool. I have no 'Clocks' icon in the toolbar, I've lost the tabs for 'Clocks Table' and 'Clocks Diagram'.
I'm using:
Version: MCUXpresso IDE v11.0.0 [Build 2516] [2019-06-05]
Operating system: Mac OS X
What do I need to do to get 'Clocks Table' and 'Clocks Diagram' back?
Solved! Go to Solution.
Hi Jon,
all config tools in MCU IDE are displayed as Eclipse Perspective (simply we can say perspective is predefined layout of windows). You can re-open perspective using `main menu - Window - Perspective - Open Perspective`
Marek
Hi Alice, that got me a 'Clocks Table' and 'Clocks Diagram' that were empty/blank.
Hi Marek, following your suggestion populated the tabs that were created by the suggestion from Alice.
My issue is now resolved.
Many thanks for your help (from both Alice and Marek) much appreciated:smileyhappy:
Hi Jon,
Marek
Hello Jon,
How about open the clock view through Window-> Show View ->other... , then search "Clock Diagram" or "Clocks Table":
I also take a video about the step, please check my attachment.
Hope it helps,
TIC
Here's log file.
On 'Project Explorer' tab, right click on .mex file, select menu item MCUEpressoConfig Tools > Open Clocks.
Clocks tool doesn't open and attached log shows java exception.
!ENTRY org.eclipse.ui 4 0 2019-08-15 10:06:55.009
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:91)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.lambda$0(LazyStackRenderer.java:75)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:147)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4932)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:219)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:132)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:139)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:4152)
at org.eclipse.ui.internal.Workbench.activate(Workbench.java:2913)
at org.eclipse.ui.internal.Workbench.showPerspective(Workbench.java:2935)
at org.eclipse.ui.internal.Workbench.showPerspective(Workbench.java:2902)
at com.nxp.swtools.common.ui.utils.perspectives.PerspectivesHelper.showPerspective(PerspectivesHelper.java:65)
at com.nxp.swtools.eclipse.OpenMexResource.openToolOrDefault(OpenMexResource.java:213)
at com.nxp.swtools.eclipse.handlers.OpenMexForProject.openConfigurationForProject(OpenMexForProject.java:102)
at com.nxp.swtools.eclipse.handlers.OpenMexForProject.execute(OpenMexForProject.java:213)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:294)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:96)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:320)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:164)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:156)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:497)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:490)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:438)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.handleWidgetSelection(AbstractContributionItem.java:449)
at org.eclipse.e4.ui.workbench.renderers.swt.AbstractContributionItem.lambda$2(AbstractContributionItem.java:475)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4319)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1512)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1535)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1520)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1324)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4143)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3760)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:563)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2019-08-15 10:06:55.112
!MESSAGE Command 'com.nxp.swtools.eclipse.openmex' failed
!STACK 0
org.eclipse.core.commands.ExecutionException: Error executing 'com.nxp.swtools.eclipse.openmex': java.lang.NullPointerException
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:170)
Caused by: org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
... 35 more
Caused by: java.lang.NullPointerException
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:4153)
... 39 more
