Crank with no gap in Engine control etpu library
folkertsikkema
Dear all,
Is it possible to use a triggerwheel with no gap in the CRANK function of the eTPU engine library?
Setting "Teeth_in_gap" to 0 suggests an extra tooth...
Regards, Folkert
folkertsikkema
Dear David,
Thank you for your answer.
This suggests that a wheel without a special trigger (missing or added tooth) wil not work.
Regards, Folkert
davidtosenovjan
Hi, I am attaching presentation slides screenshots to understand which CRANK patterns are supported. Hope it helps
