weston.ini conflicts in AGL - Imx8 build
manizillion
I see the following errors while building with the following bistro and bitbake configuration, failing at last stage of the build. Some suggestions to solve this error would be helpful.
DISTRO=imx-agl-wayland MACHINE=imx8mqevk source nxp-setup-agl.sh -b bld-agl
bitbake agl-image-weston
ERROR: agl-image-weston-1.0-r0 do_rootfs: Could not invoke dnf. Command '/home/imx8/weston-agl/bld-agl/tmp/work/imx8mqevk-poky-linux/agl-image-weston/1.0-r0/recipe-sysroot-native/usr/bin/dnf -y -c /home/imx8/weston-agl/bld-agl/tmp/work/imx8mqevk-poky-linux/agl-image-weston/1.0-r0/rootfs/etc/dnf/dnf.conf --setopt=reposdir=/home/imx8/weston-agl/bld-agl/tmp/work/imx8mqevk-poky-linux/agl-image-weston/1.0-r0/rootfs/etc/yum.repos.d --repofrompath=oe-repo,/home/imx8/weston-agl/bld-agl/tmp/work/imx8mqevk-poky-linux/agl-image-weston/1.0-r0/oe-rootfs-repo --installroot=/home/imx8/weston-agl/bld-agl/tmp/work/imx8mqevk-poky-linux/agl-image-weston/1.0-r0/rootfs --setopt=logdir=/home/imx8/weston-agl/bld-agl/tmp/work/imx8mqevk-poky-linux/agl-image-weston/1.0-r0/temp --nogpgcheck install dnf psplash rpm packagegroup-core-ssh-openssh run-postinsts packagegroup-agl-image-weston agl-desktop-config' returned 1:
Added oe-repo repo from /home/imx8/weston-agl/bld-agl/tmp/work/imx8mqevk-poky-linux/agl-image-weston/1.0-r0/oe-rootfs-repo
Last metadata expiration check: 0:00:00 ago on Mon 12 Aug 2019 06:53:59 AM UTC.
Dependencies resolved.
 Package               Arch          Version                      Repository
        Size
Installing:
 agl-desktop-config    aarch64       0.1-r0                       oe-repo 6.7 k
 dnf                   aarch64       2.6.3-r0                     oe-repo 167 k
                       noarch        1.0-r0                       oe-repo 5.5 k
                       noarch        1.0-r1                       oe-repo 5.3 k
 psplash               aarch64       0.1+git0+2015f7073e-r15      oe-repo  11 k
 rpm                   aarch64       1:4.13.90+git0+a8e51b3bb0-r0 oe-repo 353 k
 run-postinsts         noarch        1.0-r9                       oe-repo 8.3 k
Installing dependencies:
 af-binder             aarch64       master+git0+5b26086e8e-r0    oe-repo  94 k
 af-binder-tools       aarch64       master+git0+5b26086e8e-r0    oe-repo  12 k
 af-main               aarch64       master+git0+a752e8b303-r0    oe-repo  65 k
 agl-login-manager     aarch64       0.1-r0                       oe-repo 6.2 k
 agl-users             noarch        0.1-r0                       oe-repo  11 k
 base-files            imx8mqevk     3.0.14-r89                   oe-repo  15 k
 base-passwd           aarch64       3.5.29-r0                    oe-repo 6.9 k
 bash                  aarch64       4.4-r0                       oe-repo 378 k
 bind                  aarch64       9.10.5+P3-r0                 oe-repo 1.1 M
 busybox               aarch64       1.24.1-r0                    oe-repo 310 k
 coreutils             aarch64       8.27-r0                      oe-repo 699 k
 cynara                aarch64       0.14.10+git0+be455dcaf1-r0   oe-repo 368 k
 db                    aarch64       1:5.3.28-r1                  oe-repo 396 k
 dbus-1                aarch64       1.10.20-r0                   oe-repo  14 k
 dbus-cynara           aarch64       1.10.20-r0                   oe-repo 109 k
 dhcp-libs             aarch64       4.3.6-r0                     oe-repo  48 k
 dhcp-server           aarch64       4.3.6-r0                     oe-repo 236 k
 file                  aarch64       5.31-r0                      oe-repo 235 k
 fontconfig-utils      aarch64       2.12.4-r0                    oe-repo  22 k
 gpgme                 aarch64       1.9.0-r0                     oe-repo 110 k
 kbd                   aarch64       2.0.4-r0                     oe-repo 107 k
 kernel-4.9.88-imx-4.9.88-2.0.0-ga+g5e23f9d61147
                       imx8mqevk     4.9.88-r0                    oe-repo  12 k
 kernel-image-4.9.88-imx-4.9.88-2.0.0-ga+g5e23f9d61147
                       imx8mqevk     4.9.88-r0                    oe-repo 5.6 k
 kernel-image-image-4.9.88-imx-4.9.88-2.0.0-ga+g5e23f9d61147
                       imx8mqevk     4.9.88-r0                    oe-repo 6.3 M
 kernel-module-galcore-4.9.88-imx_4.9.88_2.0.0_ga+g5e23f9d61147
                       imx8mqevk     6.2.4.p1.2-r0                oe-repo 126 k
 kernel-module-imx-gpu-viv
                       imx8mqevk     6.2.4.p1.2-r0                oe-repo 5.5 k
 kmod                  aarch64       24+git0+ef4257b59c-r0        oe-repo  55 k
 libacl1               aarch64       2.2.52-r0                    oe-repo  17 k
 libafbwsc1            aarch64       master+git0+5b26086e8e-r0    oe-repo  22 k
 libarchive            aarch64       3.3.2-r0                     oe-repo 228 k
 libassuan0            aarch64       2.4.3-r0                     oe-repo  31 k
 libattr1              aarch64       2.4.47-r0                    oe-repo  12 k
 libblkid1             aarch64       2.30-r0                      oe-repo 100 k
 libboost-program-options1.64.0
                       aarch64       1.64.0-r0                    oe-repo 123 k
 libbz2-1              aarch64       1.0.6-r5                     oe-repo  31 k
 libc6                 aarch64       2.26-r0                      oe-repo 1.0 M
 libcairo2             aarch64_mx8mq 1.14.10-r0                   oe-repo 330 k
 libcap2               aarch64       2.25-r0                      oe-repo  15 k
 libcom-err2           aarch64       1.43.5-r0                    oe-repo  11 k
 libcomps0.1.8         aarch64       0.1.8+git0+01a4759894-r0     oe-repo  75 k
 libcrypto1.0.2        aarch64       1.0.2n-r0                    oe-repo 533 k
 libcurl4              aarch64       7.54.1-r0                    oe-repo 127 k
 libdbus-1-3           aarch64       1.10.20-r0                   oe-repo  98 k
 libdnf1               aarch64       0.9.3-r0                     oe-repo 108 k
 libdrm-freedreno1     aarch64       2.4.84-r0                    oe-repo  16 k
 libdrm2               aarch64       2.4.84-r0                    oe-repo  30 k
 libdw1                aarch64       0.170-r0                     oe-repo 175 k
 libe2p2               aarch64       1.43.5-r0                    oe-repo  17 k
 libegl-imx            aarch64_mx8mq 1:6.2.4.p1.2+aarch64-r0      oe-repo 329 k
 libelf1               aarch64       0.170-r0                     oe-repo  39 k
 libevdev              aarch64       1.5.7-r0                     oe-repo  36 k
 libexpat1             aarch64       2.2.3-r0                     oe-repo  62 k
 libext2fs2            aarch64       1.43.5-r0                    oe-repo 127 k
 libffi6               aarch64       3.2.1-r0                     oe-repo  20 k
 libfontconfig1        aarch64       2.12.4-r0                    oe-repo 115 k
 libfreetype6          aarch64       2.8-r0                       oe-repo 247 k
 libgal-imx            aarch64_mx8mq 1:6.2.4.p1.2+aarch64-r0      oe-repo 1.7 M
 libgbm-imx            aarch64_mx8mq 1:6.2.4.p1.2+aarch64-r0      oe-repo  51 k
 libgcc1               aarch64       7.3.0-r0                     oe-repo  37 k
 libgcrypt             aarch64       1.8.0-r0                     oe-repo 295 k
 libgles2-imx          aarch64_mx8mq 1:6.2.4.p1.2+aarch64-r0      oe-repo 1.5 M
 libglib-2.0-0         aarch64       1:2.52.3-r0                  oe-repo 785 k
 libglslc-imx          aarch64_mx8mq 1:6.2.4.p1.2+aarch64-r0      oe-repo 760 k
 libgmp10              aarch64       6.1.2-r0                     oe-repo 184 k
 libgnutls30           aarch64       3.5.13-r0                    oe-repo 398 k
 libgomp1              aarch64       7.3.0-r0                     oe-repo  63 k
 libgpg-error0         aarch64       1.27-r0                      oe-repo  33 k
 libharfbuzz0          aarch64_mx8mq 1.4.8-r0                     oe-repo 186 k
 libicudata59          aarch64       59.1-r0                      oe-repo 6.0 M
 libicuuc59            aarch64       59.1-r0                      oe-repo 553 k
 libidn11              aarch64       1.33-r0                      oe-repo  44 k
 libinput              aarch64       1.6.1-r0                     oe-repo  79 k
 libjpeg62             aarch64       1:1.5.2-r0                   oe-repo  90 k
 libjson-c2            aarch64       0.12.1-r0                    oe-repo  20 k
 libkmod2              aarch64       24+git0+ef4257b59c-r0        oe-repo  32 k
 libksba8              aarch64       1.3.5-r0                     oe-repo  76 k
 libltdl7              aarch64       2.4.6-r0                     oe-repo  19 k
 liblzma5              aarch64       5.2.3-r0                     oe-repo  69 k
 liblzo2-2             aarch64       2.10-r0                      oe-repo  40 k
 libmicrohttpd12       aarch64       0.9.55-r0                    oe-repo  42 k
 libmount1             aarch64       2.30-r0                      oe-repo 110 k
 libncurses5           aarch64       6.0+20170715-r0              oe-repo  54 k
 libncursesw5          aarch64       6.0+20170715-r0              oe-repo  70 k
 libnpth0              aarch64       1.5-r0                       oe-repo  10 k
 libpam                aarch64       1.3.0-r5                     oe-repo  31 k
 libpam-runtime        aarch64       1.3.0-r5                     oe-repo  15 k
 libpanel5             aarch64       6.0+20170715-r0              oe-repo  10 k
 libpcre1              aarch64       8.41-r0                      oe-repo  82 k
 libperl5              aarch64       5.24.1-r0                    oe-repo 611 k
 libpixman-1-0         aarch64       1:0.34.0-r0                  oe-repo 116 k
 libpng16-16           aarch64       1.6.31-r0                    oe-repo  80 k
 libpopt0              aarch64       1.16-r3                      oe-repo  24 k
 libpython3.5m1.0      aarch64       3.5.3-r1.0                   oe-repo 650 k
 libreadline7          aarch64       7.0-r0                       oe-repo 102 k
 librepo0              aarch64       1.7.20+git0+e1137cbbda-r0    oe-repo  75 k
 libsolv0              aarch64       0.6.28-r0                    oe-repo 204 k
 libsolvext0           aarch64       0.6.28-r0                    oe-repo  58 k
 libsqlite3-0          aarch64       3:3.20.0-r0                  oe-repo 341 k
 libssl1.0.2           aarch64       1.0.2n-r0                    oe-repo 122 k
 libstdc++6            aarch64       7.3.0-r0                     oe-repo 331 k
 libsystemd0           aarch64       1:234-r0                     oe-repo 170 k
 libtinfo5             aarch64       6.0+20170715-r0              oe-repo  48 k
 libudev1              aarch64       1:234-r0                     oe-repo  46 k
 libunistring2         aarch64       0.9.7-r0                     oe-repo 340 k
 libuuid1              aarch64       2.30-r0                      oe-repo  12 k
 libvsc-imx            aarch64_mx8mq 1:6.2.4.p1.2+aarch64-r0      oe-repo 2.7 M
 libweston-3           aarch64_mx8mq 3.0.0-r0                     oe-repo 150 k
 libxkbcommon0         aarch64       0.7.1-r0                     oe-repo  87 k
 libxml2               aarch64       2.9.4-r0                     oe-repo 503 k
 libxslt               aarch64       1.1.29-r0                    oe-repo 103 k
 libz1                 aarch64       1.2.11-r0                    oe-repo  44 k
 libzip                aarch64       1.1.1-r0                     oe-repo  50 k
 mtdev                 aarch64       1.1.5-r0                     oe-repo  17 k
 netbase               aarch64       1:5.4-r0                     oe-repo  15 k
 nettle                aarch64       3.3-r0                       oe-repo 231 k
 nspr                  aarch64       4.16-r0                      oe-repo 101 k
 nss                   aarch64       3.31.1-r0                    oe-repo 1.6 M
 openssh               aarch64       7.5p1-r0                     oe-repo 5.7 k
 openssh-keygen        aarch64       7.5p1-r0                     oe-repo 129 k
 openssh-scp           aarch64       7.5p1-r0                     oe-repo  35 k
 openssh-ssh           aarch64       7.5p1-r0                     oe-repo 231 k
 openssh-sshd          aarch64       7.5p1-r0                     oe-repo 265 k
 openssl               aarch64       1.0.2n-r0                    oe-repo 174 k
 openssl-conf          aarch64       1.0.2n-r0                    oe-repo 9.6 k
 packagegroup-agl-app-framework
                       noarch        1.0-r0                       oe-repo 5.4 k
 packagegroup-agl-core-automotive
 packagegroup-agl-core-connectivity
 packagegroup-agl-core-graphics
 packagegroup-agl-core-kernel
 packagegroup-agl-core-multimedia
 packagegroup-agl-core-navi-lbs
 packagegroup-agl-core-os-commonlibs
 packagegroup-agl-core-security
 packagegroup-agl-core-speech-services
 packagegroup-agl-image-minimal
                       noarch        1.0-r0                       oe-repo 5.8 k
 packagegroup-core-boot-agl
                       imx8mqevk     1.0-r0                       oe-repo 5.5 k
 pam-plugin-deny       aarch64       1.3.0-r5                     oe-repo 7.5 k
 pam-plugin-env        aarch64       1.3.0-r5                     oe-repo  11 k
 pam-plugin-faildelay  aarch64       1.3.0-r5                     oe-repo 8.6 k
 pam-plugin-group      aarch64       1.3.0-r5                     oe-repo  11 k
 pam-plugin-keyinit    aarch64       1.3.0-r5                     oe-repo 9.2 k
 pam-plugin-lastlog    aarch64       1.3.0-r5                     oe-repo  11 k
 pam-plugin-limits     aarch64       1.3.0-r5                     oe-repo  13 k
 pam-plugin-loginuid   aarch64       1.3.0-r5                     oe-repo 8.6 k
 pam-plugin-mail       aarch64       1.3.0-r5                     oe-repo 9.9 k
 pam-plugin-motd       aarch64       1.3.0-r5                     oe-repo 8.3 k
 pam-plugin-nologin    aarch64       1.3.0-r5                     oe-repo 8.6 k
 pam-plugin-permit     aarch64       1.3.0-r5                     oe-repo 7.8 k
 pam-plugin-rootok     aarch64       1.3.0-r5                     oe-repo 7.8 k
 pam-plugin-securetty  aarch64       1.3.0-r5                     oe-repo 9.3 k
 pam-plugin-shells     aarch64       1.3.0-r5                     oe-repo 8.3 k
 pam-plugin-unix       aarch64       1.3.0-r5                     oe-repo  28 k
 pam-plugin-warn       aarch64       1.3.0-r5                     oe-repo 8.1 k
 pango                 aarch64_mx8mq 1.40.6-r0                    oe-repo 139 k
 perl                  aarch64       5.24.1-r0                    oe-repo  23 k
 python3-argparse      aarch64       3.5.3-r1.0                   oe-repo  44 k
 python3-audio         aarch64       3.5.3-r1.0                   oe-repo  45 k
 python3-codecs        aarch64       3.5.3-r1.0                   oe-repo 725 k
 python3-compression   aarch64       3.5.3-r1.0                   oe-repo 105 k
 python3-core          aarch64       3.5.3-r1.0                   oe-repo 213 k
 python3-crypt         aarch64       3.5.3-r1.0                   oe-repo  27 k
 python3-curses        aarch64       3.5.3-r1.0                   oe-repo  39 k
 python3-datetime      aarch64       3.5.3-r1.0                   oe-repo  84 k
 python3-distutils     aarch64       3.5.3-r1.0                   oe-repo 992 k
 python3-email         aarch64       3.5.3-r1.0                   oe-repo 193 k
 python3-enum          aarch64       3.5.3-r1.0                   oe-repo  18 k
 python3-fcntl         aarch64       3.5.3-r1.0                   oe-repo  12 k
 python3-gpg           aarch64       1.9.0-r0                     oe-repo 173 k
 python3-html          aarch64       3.5.3-r1.0                   oe-repo  59 k
 python3-image         aarch64       3.5.3-r1.0                   oe-repo  12 k
 python3-importlib     aarch64       3.5.3-r1.0                   oe-repo  67 k
 python3-iniparse      aarch64       0.4-r0                       oe-repo  28 k
 python3-io            aarch64       3.5.3-r1.0                   oe-repo 177 k
 python3-json          aarch64       3.5.3-r1.0                   oe-repo  39 k
 python3-lang          aarch64       3.5.3-r1.0                   oe-repo 188 k
 python3-logging       aarch64       3.5.3-r1.0                   oe-repo  75 k
 python3-math          aarch64       3.5.3-r1.0                   oe-repo  42 k
 python3-mime          aarch64       3.5.3-r1.0                   oe-repo  16 k
 python3-misc          aarch64       3.5.3-r1.0                   oe-repo 2.2 M
 python3-netclient     aarch64       3.5.3-r1.0                   oe-repo 268 k
 python3-pickle        aarch64       3.5.3-r1.0                   oe-repo  72 k
 python3-re            aarch64       3.5.3-r1.0                   oe-repo  38 k
 python3-reprlib       aarch64       3.5.3-r1.0                   oe-repo 7.7 k
 python3-rpm           aarch64       1:4.13.90+git0+a8e51b3bb0-r0 oe-repo  44 k
 python3-selectors     aarch64       3.5.3-r1.0                   oe-repo  15 k
 python3-shell         aarch64       3.5.3-r1.0                   oe-repo  44 k
 python3-signal        aarch64       3.5.3-r1.0                   oe-repo 8.3 k
 python3-six           aarch64       1.10.0-r0                    oe-repo  22 k
 python3-sqlite3       aarch64       3.5.3-r1.0                   oe-repo  33 k
 python3-stringold     aarch64       3.5.3-r1.0                   oe-repo  13 k
 python3-subprocess    aarch64       3.5.3-r1.0                   oe-repo  36 k
 python3-textutils     aarch64       3.5.3-r1.0                   oe-repo  61 k
 python3-threading     aarch64       3.5.3-r1.0                   oe-repo  38 k
 python3-unixadmin     aarch64       3.5.3-r1.0                   oe-repo  17 k
 run-agl-postinsts     noarch        1.0-r0                       oe-repo 8.0 k
 security-manager      aarch64       1.0.2+git0+860305a595-r0     oe-repo 210 k
 security-manager-policy
                       aarch64       1.0.2+git0+860305a595-r0     oe-repo 9.0 k
 shadow                aarch64       4.2.1-r0                     oe-repo 180 k
 shadow-base           aarch64       4.2.1-r0                     oe-repo  42 k
 shadow-securetty      imx8mqevk     4.2.1-r3                     oe-repo 6.5 k
 smack                 aarch64       1.3.0+git0+478f68d182-r0     oe-repo  26 k
 sqlite3               aarch64       3:3.20.0-r0                  oe-repo  47 k
 systemd               aarch64       1:234-r0                     oe-repo 1.4 M
 systemd-agl-sync      aarch64       1.0-r0                       oe-repo 6.2 k
 systemd-container     aarch64       1:234-r0                     oe-repo 112 k
 systemd-serialgetty   imx8mqevk     1.0-r5                       oe-repo 7.3 k
 systemd-vconsole-setup
                       aarch64       1:234-r0                     oe-repo  13 k
 udev                  aarch64       1:234-r0                     oe-repo 272 k
 update-alternatives-opkg
                       aarch64       0.3.5-r0                     oe-repo 8.2 k
 update-rc.d           noarch        0.7-r5                       oe-repo 8.0 k
 util-linux-agetty     aarch64       2.30-r0                      oe-repo  25 k
 util-linux-mount      aarch64       2.30-r0                      oe-repo  17 k
 util-linux-sulogin    aarch64       2.30-r0                      oe-repo  22 k
 volatile-binds        noarch        1.0-r0                       oe-repo 8.9 k
 wayland               aarch64       1.13.0-r0                    oe-repo  42 k
 weston                aarch64_mx8mq 3.0.0-r0                     oe-repo 680 k
 weston-examples       aarch64_mx8mq 3.0.0-r0                     oe-repo 197 k
 weston-ini-conf       imx8mqevk     1.0-r0                       oe-repo 6.4 k
 weston-init           noarch        1.0-r0                       oe-repo 9.9 k
 xkeyboard-config      aarch64       2.21-r0                      oe-repo 316 k
 xmlsec1               aarch64       1.2.24-r0                    oe-repo 220 k
Installing weak dependencies:
 busybox-syslog        aarch64       1.24.1-r0                    oe-repo 8.8 k
 busybox-udhcpc        aarch64       1.24.1-r0                    oe-repo 7.8 k
 ca-certificates       noarch        20170717-r0                  oe-repo 155 k
 dhcp-server-config    aarch64       4.3.6-r0                     oe-repo 8.0 k
 e2fsprogs-e2fsck      aarch64       1.43.5-r0                    oe-repo 107 k
 gnupg                 aarch64       2.2.0-r0                     oe-repo 1.0 M
 kbd-consolefonts      aarch64       2.0.4-r0                     oe-repo 416 k
 kbd-keymaps           aarch64       2.0.4-r0                     oe-repo 453 k
 kernel-module-ipv6-4.9.88-imx_4.9.88_2.0.0_ga+g5e23f9d61147
                       imx8mqevk     4.9.88-r0                    oe-repo 140 k
 liberation-fonts      noarch        1:2.00.1-r0                  oe-repo 1.4 M
 ncurses-terminfo-base aarch64       6.0+20170715-r0              oe-repo  13 k
 os-release            noarch        1.0-r0                       oe-repo 6.0 k
 pinentry              aarch64       1.0.0-r0                     oe-repo  28 k
 psplash-default       aarch64       0.1+git0+2015f7073e-r15      oe-repo  48 k
 python3-readline      aarch64       3.5.3-r1.0                   oe-repo  18 k
 shared-mime-info      aarch64       1.8-r0                       oe-repo 360 k
 systemd-compat-units  aarch64       1.0-r29                      oe-repo 6.0 k
 systemd-extra-utils   aarch64       1:234-r0                     oe-repo  81 k
 tzdata                noarch        2018c-r0                     oe-repo  41 k
 udev-hwdb             aarch64       1:234-r0                     oe-repo 708 k
 util-linux-fsck       aarch64       2.30-r0                      oe-repo  23 k
Transaction Summary
Install  249 Packages
Total size: 54 M
Installed size: 221 M
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Error: Transaction check error:
  file /etc/xdg/weston/weston.ini conflicts between attempted installs of weston-ini-conf-1.0-r0.imx8mqevk and weston-3.0.0-r0.aarch64_mx8mq
Error Summary
ERROR: agl-image-weston-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/imx8/weston-agl/bld-agl/tmp/work/imx8mqevk-poky-linux/agl-image-weston/1.0-r0/temp/log.do_rootfs.21004
ERROR: Task (/home/imx8/weston-agl/sources/meta-agl/meta-agl-profile-graphical/recipes-graphics/images/agl-image-weston.bb:do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3571 tasks of which 3555 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Labels (2)
Tags (3)
gusarambula
Hello Manivannan s,
The AGL demo is provided “as is”, as a proof of concept, and it was tested only on the i.MX6Q so no support is provided for this demo and it hasn’t been tested on the i.MX8M.
You can find the readme here:
http://git.freescale.com/git/cgit.cgi/imx/meta-nxp-agl.git/tree/README.txt?h=krogoth
And the repository on the following git server:
My apologies for the inconvenience.
manizillion
Hi Gusarambula,
thanks for the reply, since we are trying to AGL on imx8, we could build agl-image-minimal and bring up on it. But with agl-image- Weston and agl-image-ivi the issues are coming,
Is there any workaround solution you can suggest such that we build the agl-image-weston  (imx8mqevk) configuration without errors, Or you conclude to say that it wont work for imx8?
Mani
Vis785
Have you built images for other target as well.
I found issues even in building for agl-minimal. qemu and lingpg related errors that what I am getting. I am doing it for imx8 and host is ubuntu 20.04.
Vis
gusarambula
Hello Manivannan s,
The i.MX8 does have support for wayland Weston graphics and should be technically capable of running the demo, if you put time into figuring out the dependencies.
It seems that there is a conflict on the Weston version. Since the demo is set for i.MX6Q it could be that a fixed Weston version is preferred and it’s conflicting with the i.MX8 version. You could try to resolve this albeit you would need to be careful that the rest of the demo can run on the i.MX8 supported westion version.
I hope this helps!
manizillion
Hi Gusarambula ,
Is there any similar issues seen with imx6sabre ? recently i received a suggestion mail (below in bold) which said we can follow the same steps which were done for imx6 sabreauto and make it work for imx8. If so can you please share link or reference steps which was done on imx6 so that we could follow same for our platform?
whatever tree you’re using that has a “nxp-setup-agl.sh” script isn’t mainline AGL and seems likely to be a NXP provided thing. If that’s the case, you’ll need to ask them for help, as we’ve no idea what’s in that tree.
If you can live with using the open source etnaviv driver instead of the binary Vivante driver, you could try adding a machine definition for the imx8mqevk to the AGL master branch. It shouldn’t be too hard if you follow what’s done for one of the i.MX6 boards like the sabreauto.
gusarambula
Hello Manivannan s,
All information on this demo is available in the links I shared. As you may see documentation for this demo is limited so there is no much information on the steps followed to enable the AGL demo on the i.MX6 Auto board.
The suggestion of adding the imx8mqevk MACHINE configuration to the AGL master branch may work although it’s also not a trivial process. You would need to find the imx8mqevk.conf files (and all files required by this .conf file) and add them to the AGL master branch and then edit the image recipes accordingly.
In theory is possible and sounds straightforward but it would require some work and knowing how Yocto works.
We have a BSP porting guide, which is a bit general:
 https://www.nxp.com/docs/en/user-guide/i.MX_BSP_Porting_Guide_Linux.pdfhttps://www.nxp.com/docs/en/user-guide/i.MX_BSP_Porting_Guide_Linux.pdf
And there is also the Yocto BSP Developer’s Guide, although it includes only very general instructions.
https://www.yoctoproject.org/docs/current/bsp-guide/bsp-guide.html
I hope this helps!
manizillion
Thanks for your replies sir, will work towards it just one more question,
How to add NXP's meta-fsl-bsp-release layer to the tree to pick up the new 4.19 linux-imx kernel and weston 6.0.0.imx
tree is imx-linux-thud
manizillion
Also ,
I would like to know what steps are followed to build.
Should we follow the build steps for imx8 similar to steps mentioned in AGL website like given below ?
agl-distro:agl-raspberrypi [Automotive Linux Wiki]
OR
Should we modify the steps similar to one given in NXP website ?
meta-nxp-agl - i.MX Yocto Project AGL Demo Layer
gusarambula
Hello Manivannan s,
You may add a new layer on the conf/bblayers.conf file on your build directory. You can check that the layer was added by running:
$ bitbake-layers show-layers
However, keep in mind that there may be dependencies and conflicts between the layers. As the approach you may start with either the AGL website or NXP website and work from there. I would probably recommend the AGL website at least for the majority of the recipes, and the kernel from the NXP website (which you would need to adapt for AGL).
I hope this helps!
manizillion
Hi Gusarambula,
Just a questions, if i have to include 4.19 linux-imx kernel to the AGL build steps, how to do it ?
Will adding meta-fsl-bsp-release layer to the /build/conf/bblayers.conf automatically take 4.19 linux-imx kernel while building.
We were following the steps from this Jira ticket raised by us.
[SPEC-2748] Apps install errors( afm utils, DBUS api), Imx8 platform, agl-image-minimal, - Automotiv...
How to enable Vivante graphic drivers? Please share us some reference sources if any team has done it.
appreciate your support,
Thanks and Regards
Mani
gusarambula
Hello Manivannan s,
I see that there has been some follow up on the Jira AGL Development. Hopefully they may provide further help.
As for the GPU drivers I would recommend referring to the i.MX Linux Reference Manual which is part of the BSP Releases documentation. If you are using a Community BSP kernel you may use the closest BSP Release kernel version as reference. Adding the meta-fsl-bsp-release layer will change the default kernel as the layer has a higher priority but you may force the preferred version or try lowering the meta- bsp-release priority.
I hope this helps!
manizillion
Hi Sir,
Your response has been very helpful, can you share little more details on Howto. is there any web reference to solve this issue which you know ?
Thanks and Regards
Mani
