flex-builder -c apps -a arm64 problem
yi-linhsieh
Hi all,
I tried  build apps for ls1046a platfrom.
I download and untar  flexbuild_lsdk1903.tgz
source setup.env
flex-builder -c linux -a arm64
flex-builder -i mkrfs
and it will stop at
/usr/lib/gcc-cross/aarch64-linux-gnu/7/../../../../aarch64-linux-gnu/bin/ld: cannot find -lxml2
collect2: error: ld returned 1 exit status
How I to install the xml2 library in flex-builder enviroment?
yipingwang
Hello Yi-Lin Hsieh,
Please make sure the command "flex-builder -i mkrfs  -a arm64" has completed successfully, please make sure there is no networking connection problem.
You could run the following commands to download rootfs again.
$ flex-builder -i mkrfs  -a arm64 -i clean-rfs
Yiping
