S32K146 Boot issue
S32K146 Boot issue
79vlfdy
I have the same problem. So, the community were checked.
But,  it has not yet been resolved.
Can you help me?  A detailed description is required.
If possible, please check the below.
[build tool]
1. S/W tool : S32K Design Studio & PE-micro
2. H/W tool : S32K146 EVB
                     Self-developed product(proto type)
[Problem]
1. Proto-type board is not work.
     -. PE-micro do not recognize Proto-type.
     -. (Proto-type)Reset pin toggles about every 120us.
2. S32K146 EVB board is not work.
     -. PE-micro do not recognize (JTAG mode)
