Bus throughput of i.MX8M Mini
takayuki_ishii
Hello community,
Our customer hope to know a bus throughput of i.MX8M Mini.
So please suggest following bus width and clock frequency of each bus master peripheral.
1. CPU - AXI switch fabric
2. DDR - AXI switch fablic
3. PCIe - AXI switch fablic
I can found only 2.DDR - AXI.
In reference manual 9.1.1.1 DRAM Interface,
   • 750MHz 128-bit AXI bus
But other 1 and 3 connection of master device can not found.
Do you mind explaining this in more detail?
Ishii.
Hi Ishii
it is the same as described in "9.1.1.1 DRAM Interface", since for interconnections
main NoC is used as central inter-connect fabric, which runs at 750MHz.
sorry this is internal design information, closed for customers. Please apply
to local NXP office to get more details.
Hi Ishii
takayuki_ishii
Hello Igor,
Thank you for your response.
Can I get a AXI bus width?
Is it need to ask local FAE?
Ishii.
Hi Ishii
yes please ask this through local nxp marketing office.
takayuki_ishii
Hello Igor,
Thank you for your quick response.
I will ask it to local marketing member.
Ishii.
