Hi, all
From the official document "AN12149.pdf", I know PTPd had been perfectly implemented with hardware timestamp support. as the document state, I download NXP MCUXpresso SDK 2.4.x IDE for i.MX RT10xx EVK boards, but I
found the no 2.4.x version for i.MX RT 10xx exist, only 2.6.x or 2.5.0, Meanwhile, I also found the no other PTP implementation is for 2.6.x or 2.5.0 except for ptp implementation in enet driver.
my question is, Is the ptp fully implementation on i.MX RT10xx EVK board only for SDK 2.4.x version ?
if any other reason, pls tell me, thanks
Neil Liu
I think AN12149 doesn't talk about MCUXspresso IDE but a different one called IAR Embedded Workbench.
I am also interested in locating this demo. Did you make any progress?
Please find it as the example. \iMXRT\EVKB-IMXRT1050_SDK_2_5_0\boards\evkbimxrt1050\driver_examples\enet\txrx_ptp1588_transfer.
Hope it help you.
The txrx_ptp1588_transfer project is not the ptp deamon project.
I'm not able to find the project described in AN12149.
Using MCUXspresso IDE v11.3.1 and SDK version 2.9.1
Best Regards
