PWM not found in MCUXpresso Config Tools i.Mx1060
mariuslucianand
I am using the i.Mx 1060 with the SDK_2.x_EVK-MIMXRT1060. I've opened the evkmimxrt1060_pwm example but I can't find the PWM under the MCUXpresso Config Tools Peripherals or Components. I was expecting to find the eFlexPWM or PWM same as for let's say LPUART. How can I get the support for PWM in the MCUXpresso Config Tool?
Thank you,
Marius
jeremyzhou
Hi Marius Lucian Andrei,
Yes, the FlexPWM module hasn't be integrated into the MCUXpresso config tool, in another word, it's unavailable to support the FlexPWM module now.
Hope this is clear.
TIC
jeremyzhou
Hope this is clear.
TIC
kurt_staubli
Hello
Is there a published roadmap for the Configuration Tool? I am using RT1060 and I have the feeling that the Peripheral Tool is not yet mature or I do not quite understand it. How is it for example possible to route a PWM output to trigger an ADC conversion with the Peripheral Tool?
Kurt
mariuslucianand
Hello jeremyzhou‌,
Thank you very much for your response! Can you estimate when or if the FlexPWM will be available?
Marius
