Compiler error: 'BOARD_INITPINS_KW41_RST_GPIO_PIN' undeclared (first use in this function); did you mean 'BOARD_INITPINS_KW41_RST_GPIO'?
alejandro_abrah
I have installed the newest SDKs in MCUXpresso but I cannot get rid of the error:
What could I do to solve this ?
Thank you.
Best,
Alejandro
theophileleroy
Please update to the latest version of MCUXpresso & pin tool configurators.
alejandro_abrah
I believe I have the latest version of MCUXpresso: v10.3.1_2233.
Under Product Information:
Product: MCUXpresso IDE
Version: MCUXpresso IDE v10.3.1
Operating system: Windows 10
VM: Java HotSpot(TM) Client VM (32 bit)
Plugins and versions:
- com.crt.advproject (10.3.1.201902111813)
- com.crt.config (10.3.1.201902111813)
- com.crt.ctrlcenter (10.3.0.201811021503)
- com.crt.debugcommon (10.3.1.201902131125)
- com.crt.dsfdebug (10.3.1.201902111813)
- com.crt.lite (10.3.0.201808091259)
- com.crt.lpcxpresso.brand (10.3.1.201902111813)
- com.crt.quickstart (10.3.0.201811021153)
- com.crt.utils (10.3.1.201902111813)
- com.crt.vendor.arm.generic (10.3.0.201808091259)
- com.crt.vendor.nxp.generic (10.3.0.201808091259)
- com.crt.vendor.nxp.lpc11 (10.3.0.201808091259)
- com.crt.vendor.nxp.lpc13 (10.3.0.201808091259)
- com.crt.vendor.nxp.lpc17 (10.3.0.201808091259)
- com.crt.vendor.nxp.lpc18 (10.3.0.201808091259)
- com.crt.vendor.nxp.lpc43 (10.3.0.201810041206)
- com.crt.vendor.nxp.niobe (10.3.0.201808091259)
- com.crt.vendor.nxp.pn7xxxxx (10.3.0.201810041206)
- com.nxp.dfu (10.3.0.201808091259)
- com.nxp.gnudocs (10.3.0.201808091259)
- com.nxp.hid (10.3.0.201808091259)
- com.nxp.hidapi (10.3.0.201810041206)
- com.nxp.kex.standalone (1.0.0.201811140908)
- com.nxp.lpcxpresso.debug.ui (10.3.1.201902111813)
- com.nxp.lpcxpresso.installation.docs (10.3.0.201808091259)
- com.nxp.lpcxpresso.instructiontrace.docs (10.3.0.201808091259)
- com.nxp.lpcxpresso.powermeasurement.docs (10.3.0.201808091259)
- com.nxp.lpcxpresso.swotrace.docs (10.3.0.201808091259)
- com.nxp.lpcxpresso.userguide.docs (10.3.0.201808091259)
- com.nxp.mcuxpresso.addons.docsupport (10.3.0.201811161230)
- com.nxp.mcuxpresso.addons.sdkbuilder (10.3.1.201902111813)
- com.nxp.mcuxpresso.addons.svdviewer (10.3.0.201810041206)
- com.nxp.mcuxpresso.core.common (10.3.0.201811281410)
- com.nxp.mcuxpresso.core.datamodels (10.3.1.201902111813)
- com.nxp.mcuxpresso.core.datamodels.develop (10.3.0.201811271107)
- com.nxp.mcuxpresso.core.datamodels.interfaces (10.3.0.201810041206)
- com.nxp.mcuxpresso.core.datamodels.resources (10.3.0.201810041206)
- com.nxp.mcuxpresso.core.datamodels.ui (10.3.1.201902181432)
- com.nxp.mcuxpresso.core.debug (10.3.1.201902111813)
- com.nxp.mcuxpresso.core.debug.support.pe (10.3.1.201902111813)
- com.nxp.mcuxpresso.core.debug.support.segger (10.3.1.201902111813)
- com.nxp.mcuxpresso.core.headless (10.3.1.201902181432)
- com.nxp.mcuxpresso.power.core (10.3.0.201808091259)
- com.nxp.mcuxpresso.power.core.linkserver (10.3.0.201810111047)
- com.nxp.mcuxpresso.power.ui (10.3.0.201808091259)
- com.nxp.mcuxpresso.rtos.docs (10.3.0.201808091259)
- com.nxp.mcuxpresso.swo.core (10.3.0.201811231255)
- com.nxp.mcuxpresso.swo.ui (10.3.0.201811211600)
- com.nxp.mcuxpresso.tools.bin.win32 (10.3.1.201902111813)
- com.nxp.mcuxpresso.tools.win32 (10.3.0.201811011841)
- com.nxp.mcuxpresso.tools.wizards (10.3.0.201810311031)
- com.nxp.mcuxpresso.trace.core (10.3.0.201810041206)
- com.nxp.mcuxpresso.trace.core.linkserver (10.3.0.201810181304)
- com.nxp.mcuxpresso.trace.ui (10.3.0.201811191442)
- com.nxp.redlinkclient (10.3.0.201808091259)
- com.nxp.swtools.clocks (5.0.0.201811140908)
- com.nxp.swtools.clocks.model (1.0.0.201811140908)
- com.nxp.swtools.clocks.swt (1.0.0.201811140908)
- com.nxp.swtools.common.ui.utils (1.4.0.201811140908)
- com.nxp.swtools.common.ui.utils.swt (1.2.0.201811140908)
- com.nxp.swtools.common.utils (1.1.1.201811140908)
- com.nxp.swtools.configuration (1.6.0.201811140908)
- com.nxp.swtools.core (1.10.0.201811140908)
- com.nxp.swtools.core.service (1.13.0.201811140908)
- com.nxp.swtools.dashboard (1.0.0.201811140908)
- com.nxp.swtools.databinding (1.4.0.201811140908)
- com.nxp.swtools.derivative (1.0.0.201811140908)
- com.nxp.swtools.doc.mcux.ide (1.0.0.201811140908)
- com.nxp.swtools.docannotations (1.0.0.201811140908)
- com.nxp.swtools.eclipse (1.0.0.201811140908)
- com.nxp.swtools.expert (1.0.0.201811140908)
- com.nxp.swtools.framework (4.0.0.201811140908)
- com.nxp.swtools.mcuxpressoide.adapter (1.0.0.201811140908)
- com.nxp.swtools.mcuxpressoide.addons (1.0.0.201811140908)
- com.nxp.swtools.mux (5.0.0.201811140908)
- com.nxp.swtools.mux.swt (1.0.0.201811140908)
- com.nxp.swtools.periphs.controller (0.0.1.201811140908)
- com.nxp.swtools.periphs.gui (5.0.0.201811140908)
- com.nxp.swtools.periphs.gui.swt (0.0.1.201811140908)
- com.nxp.swtools.periphs.model (0.0.1.201811140908)
- com.nxp.swtools.rcp.analytics (1.0.0.201811140908)
- com.nxp.swtools.sdkmanifest (1.0.0.201811140908)
- com.nxp.swtools.sdkproject (1.0.0.201811140908)
- com.nxp.swtools.sharedconfiguration (1.1.0.201811140908)
- com.nxp.swtools.tutorial (1.0.0.201811140908)
- com.nxp.swtools.ui.inspector (1.10.0.201811140908)
- com.nxp.swtools.ui.inspector.graphical (1.3.0.201811140908)
- com.nxp.swtools.ui.targetcpu (1.6.0.201811140908)
- com.nxp.swtools.ui.views (1.0.0.201811140908)
- com.nxp.swtools.utils (1.0.0.201811140908)
- com.nxp.swtools.utils.support.markdown (1.0.0.201811140908)
- com.nxp.swtools.utils.swt (1.0.0.201811140908)
- com.nxp.swtools.validation (1.1.0.201811140908)
- com.nxp.symbolbrowser (10.3.0.201808091259)
- com.nxp.freertos.gdb.tad (1.0.8.201810241449)
I think these are the latest, or is something wrong ?
Thank you.
Best,
Alejandro
estephania_mart
I believe those are not the latest version, still , do you have the issue just with the SDK or is it with a project you imported?
Regards ,
Estephania
alejandro_abrah
Hi Estephania,
There are the steps I follow:
1. Import SDK from NXP website: SLN-RPK-NODE-SDK.zip
2. Import SDK Example from MCUXPresso
3. Set the options for the Hello World example.
4. Replace THCI_Debug with printf
5. Buil and I get no error at all:
6. I go to ConfigTools from within MCUXpresso and select: "rapid_iot_k64f_hello_world".
7. Once it finally loads, I hit "update project"
8. THen go back to "Develop".
9. Build and I now have lots of errors again:
I cannot attach the Hello World exported project from my IDE at this section.
Thank you.
Best,
Alejandro
estephania_mart
While we check, could you please try checking this meanwhile ?
Estephania
