Yocto compilation
Question asked by sergio d'orazio on Jul 24, 2019
Latest reply on Sep 3, 2019 by gusarambula
I am using yocto project for compile my linux on IMX6ULL EVK.
I am starting from Image 'core-image-base' and I am adding some modules with command IMAGE_INSTALL_append =  "lighttpd curl libstdc++ bluez5" in local.conf file.
I build with bitbake command and I have a file system with new modules.
But when I run these mudules there are errors: some library file not found because the folder 'modules' in '~/imx-yocto-bsp/Linux-RCA2/tmp/deploy/images/imx6ull14x14evk'  is not update with new modules, infact the date of this folder is old.
What is the command for update this folder ?
By.
Sergio.
