Using SVM etpu api
Using SVM etpu api
amey_murkute
Hi all,
      I am using MPC5777C for my project & implementing SVM. As I have seen that NXP has provided 3 api function's for SVM are
1) FS_ETPU_PWMMAC_MOD_SVM_STD
2) FS_ETPU_PWMMAC_MOD_SVM_U0N
3) FS_ETPU_PWMMAC_MOD_SVM_U7N
  I am using the first one method in my implementation but I want to know the difference between the two.
The main question is when I am using the STD mod SVM API , we need to feed alpha & beta to the API. But only feeding this, it wont work... after multiplying some constant to alpha & beta it is working fine. So is this correct?
davidtosenovjan
Yes, I understand it this way.
The difference you may see in the following pictures:
amey_murkute
Hi david,
       Thanks for your responce.
