Where can be files downloaded for AN12384 - LPC5460x UART Secondary Bootloader using YMode ?
PabloBaena
Hello all,
As explained on this thread (https://community.nxp.com/message/1148660?commentID=1148660#comment-1148660), AN12384 PDF shows UART secondary bootloader for LPC5460x, the document says that there are available packed files for testing the solution.  Please anyone knows the link for downloading the pack of files?
From page 15:
..."The SBL project and the modifed hello_world and rit_example demo projects from MCUXpresso SDK software library are packed alone with this application note. The projects are originally developed with Keil IDE, but can be easily ported to other IAR IDE like MCUXpresso IDE or IAR IDE. "....
Thanks in advance!
Alexis_A
Dear PabloBaena‌,
Please check the following link.
This is a link to the documentation section of the LPC546xxn, in the  Application Note section you can find a link to this document an bellow the software you're looking for.
I hope this helps you.
Alexis Andalon
Alexis_A
Dear PabloBaena‌,
Alexis Andalon
PabloBaena
Thank you very much.
