the variable define by FLEXIO_UART_Type unwork
wuyunfeng
i build a new project to test flexio function,and i copy the code from the example project (flexio_uart_interrupt_transfer). but when i start debug,i find that the variable define by FLEXIO_UART_Type is null, the function cant get in when it use the pointer of the variable.
jingpan
Can you give more detail about your problem? Are you using KL28?
Jing
