LPC55 USB Bootloader
jonathanmccarro
Is it possible to get an example for HID Bootloader for the LPC55. Ideally I would like to use the HS USB port to achieve this.
soledad
Unfortunately, there is no example for HID Bootloader for the LPC55sxx.  You can check the application note AN12327 "Firmware Update Using Secondary Bootloader".
https://www.nxp.com/docs/en/application-note/AN12327.pdf
You can use it as a reference.
Have a nice day!
Soledad
