[IMX8MMINILPD4-EVK - Bluetooth] How to transfer files between BLE devices?
expman99
I am new to bluetooth field. I would like to use imx8mm as a BLE device that can play GATT server role for file transferring with smartphone and pc.
I found Object Transfer Profile and  Object Transfer Service profiles on https://www.bluetooth.com/specifications/gatt/ but I do not know how to use them with imx8mm.
Anyone can help me the way to use them or other profiles or custom profile code example for this problem?
Thank you,
expman99
Thank Kunal Kotecha,
I use the EVK as BLE device, not classic device. I solved my problem.
kunalkotecha1
Senior Contributor II
Hi expman99@gmail.com,
I assume you are using i.MX8M Mini EVK. I have tested the bluetooth on this evk and connected the same with smartphone. For doing the same you can refer the attached "i.MX_Linux_User's_Guide.pdf", section 10.1.
Also, for various bluetooth services and operations, you can use the utility like bluetoothctl or obexftp for file transfer.
Kunal
