Hello ı am working on imxrt1050 evk and when ı tried to connect board with my computer this error appears. How can ı solve this problem?
Solved! Go to Solution.
To solve the issue, I think I need to know more information about it, so whether you can introduce the complete testing steps you did, for instance, the demo code, evaluation board, etc.
Looking forward to your reply.
TIC
TIC
Hi jeremyzhou thank you for your answer. I change board settings and errors disappears.
