Hello Aravind,
1) did you create the project using clonins SDK example?
2) could you attach here log file from <workspace>/.metadata/.log ?
Thank you,
Libor
!SESSION 2019-07-17 11:06:14.729 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_181
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_IN
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file C:\Users\sabari\Documents\MCUXpressoIDE_10.3.1_2233\workspace\.metadata\.bak_1.log
Created Time: 2019-07-17 18:24:03.349
!ENTRY org.eclipse.debug.ui 4 120 2019-07-17 18:24:03.349
!MESSAGE Error logged from Debug UI:
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@1ecb6c0 rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@1b930b5[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 9057]
at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2063)
at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:830)
at java.util.concurrent.ScheduledThreadPoolExecutor.delayedExecute(ScheduledThreadPoolExecutor.java:326)
at java.util.concurrent.ScheduledThreadPoolExecutor.schedule(ScheduledThreadPoolExecutor.java:533)
at org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor.schedule(DefaultDsfExecutor.java:438)
at java.util.concurrent.ScheduledThreadPoolExecutor.submit(ScheduledThreadPoolExecutor.java:632)
at org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor.submit(DefaultDsfExecutor.java:470)
at org.eclipse.cdt.dsf.debug.ui.actions.DsfStepReturnCommand.canExecute(DsfStepReturnCommand.java:53)
at org.eclipse.debug.internal.ui.commands.actions.DebugCommandService.updateCommand(DebugCommandService.java:178)
at org.eclipse.debug.internal.ui.commands.actions.DebugCommandService.postUpdate(DebugCommandService.java:153)
at org.eclipse.debug.internal.ui.commands.actions.DebugCommandService.debugContextChanged(DebugCommandService.java:234)
at org.eclipse.debug.internal.ui.contexts.DebugWindowContextService$2.run(DebugWindowContextService.java:231)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.debug.internal.ui.contexts.DebugWindowContextService.notify(DebugWindowContextService.java:228)
at org.eclipse.debug.internal.ui.contexts.DebugWindowContextService.notify(DebugWindowContextService.java:212)
at org.eclipse.debug.internal.ui.contexts.DebugWindowContextService.debugContextChanged(DebugWindowContextService.java:452)
at org.eclipse.debug.ui.contexts.AbstractDebugContextProvider$1.run(AbstractDebugContextProvider.java:82)
at org.eclipse.debug.ui.contexts.AbstractDebugContextProvider.fire(AbstractDebugContextProvider.java:79)
at org.eclipse.debug.internal.ui.views.launch.LaunchView$ContextProviderProxy.debugContextChanged(LaunchView.java:519)
at org.eclipse.debug.internal.ui.views.launch.LaunchView$TreeViewerContextProvider.possibleChange(LaunchView.java:405)
at org.eclipse.debug.internal.ui.views.launch.LaunchView$TreeViewerContextProvider$Visitor.visit(LaunchView.java:327)
at org.eclipse.cdt.dsf.ui.viewmodel.VMDelta.doAccept(VMDelta.java:365)
at org.eclipse.cdt.dsf.ui.viewmodel.VMDelta.doAccept(VMDelta.java:368)
at org.eclipse.cdt.dsf.ui.viewmodel.VMDelta.accept(VMDelta.java:360)
at org.eclipse.debug.internal.ui.views.launch.LaunchView$TreeViewerContextProvider.modelChanged(LaunchView.java:435)
at org.eclipse.debug.internal.ui.viewers.model.TreeModelContentProvider.doModelChanged(TreeModelContentProvider.java:431)
at org.eclipse.debug.internal.ui.viewers.model.TreeModelContentProvider.modelChanged(TreeModelContentProvider.java:400)
at org.eclipse.cdt.dsf.ui.viewmodel.DefaultVMModelProxyStrategy$1.run(DefaultVMModelProxyStrategy.java:155)
at org.eclipse.cdt.dsf.ui.viewmodel.DefaultVMModelProxyStrategy.fireModelChanged(DefaultVMModelProxyStrategy.java:159)
at org.eclipse.cdt.dsf.ui.viewmodel.update.AbstractCachingVMProvider$6.handleSuccess(AbstractCachingVMProvider.java:898)
at org.eclipse.cdt.dsf.concurrent.RequestMonitor.handleCompleted(RequestMonitor.java:385)
at org.eclipse.cdt.dsf.concurrent.RequestMonitor$2.run(RequestMonitor.java:312)
at org.eclipse.cdt.dsf.ui.concurrent.SimpleDisplayExecutor.runInSwtThread(SimpleDisplayExecutor.java:117)
at org.eclipse.cdt.dsf.ui.concurrent.SimpleDisplayExecutor$1.run(SimpleDisplayExecutor.java:80)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:37)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4213)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3820)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
!ENTRY com.crt.log 4 -1 2019-07-17 18:24:03.524
!MESSAGE Document is closed
!STACK 0
java.lang.Exception: java.io.IOException: Document is closed
at com.crt.utils.general.Reporter.log(Reporter.java:654)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.log(MCXTelnetService.java:418)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.shutdown(MCXTelnetService.java:197)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.launchesTerminated(MCXTelnetService.java:283)
at org.eclipse.debug.internal.core.LaunchManager$LaunchesNotifier.run(LaunchManager.java:314)
at org.eclipse.debug.internal.core.LaunchManager$LaunchesNotifier.notify(LaunchManager.java:266)
at org.eclipse.debug.internal.core.LaunchManager.fireUpdate(LaunchManager.java:1054)
at org.eclipse.debug.core.Launch.fireTerminate(Launch.java:479)
at org.eclipse.cdt.dsf.debug.model.DsfLaunch.access$1(DsfLaunch.java:1)
at org.eclipse.cdt.dsf.debug.model.DsfLaunch$2.run(DsfLaunch.java:52)
at org.eclipse.debug.core.DebugPlugin$AsynchRunner.run(DebugPlugin.java:1110)
at org.eclipse.debug.core.DebugPlugin$AsynchRunner.async(DebugPlugin.java:1091)
at org.eclipse.debug.core.DebugPlugin$EventDispatchJob.run(DebugPlugin.java:440)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
Caused by: java.io.IOException: Document is closed
at org.eclipse.ui.internal.console.IOConsolePartitioner.streamAppended(IOConsolePartitioner.java:462)
at org.eclipse.ui.console.IOConsoleOutputStream.notifyParitioner(IOConsoleOutputStream.java:295)
at org.eclipse.ui.console.IOConsoleOutputStream.encodedWrite(IOConsoleOutputStream.java:290)
at org.eclipse.ui.console.IOConsoleOutputStream.write(IOConsoleOutputStream.java:274)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.log(MCXTelnetService.java:412)
... 14 more
!ENTRY com.crt.log 4 -1 2019-07-17 18:24:03.529
!STACK 0
at com.crt.dsfdebug.dsf.services.MCXTelnetService.lf(MCXTelnetService.java:451)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.shutdown(MCXTelnetService.java:196)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.launchesRemoved(MCXTelnetService.java:215)
at org.eclipse.debug.internal.core.LaunchManager$LaunchesNotifier.run(LaunchManager.java:283)
at org.eclipse.debug.internal.core.LaunchManager.removeLaunch(LaunchManager.java:2245)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationManager.removeTerminatedLaunches(LaunchConfigurationManager.java:330)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationManager.launchAdded(LaunchConfigurationManager.java:316)
at org.eclipse.debug.internal.core.LaunchManager$LaunchNotifier.run(LaunchManager.java:446)
at org.eclipse.debug.internal.core.LaunchManager$LaunchNotifier.notify(LaunchManager.java:433)
at org.eclipse.debug.internal.core.LaunchManager.fireUpdate(LaunchManager.java:1043)
at org.eclipse.debug.internal.core.LaunchManager.addLaunch(LaunchManager.java:703)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:834)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
at org.eclipse.ui.console.IOConsoleOutputStream.close(IOConsoleOutputStream.java:179)
at org.eclipse.ui.console.IOConsoleOutputStream.notifyParitioner(IOConsoleOutputStream.java:304)
at org.eclipse.ui.console.IOConsoleOutputStream.write(IOConsoleOutputStream.java:209)
at org.eclipse.ui.console.IOConsoleOutputStream.write(IOConsoleOutputStream.java:225)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.lf(MCXTelnetService.java:442)
... 20 more
!ENTRY com.crt.log 4 -1 2019-07-17 18:24:03.554
!STACK 0
... 20 more
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 18:24:09.238
!MESSAGE Telnet session connected on port 3332->60506 @ 127.0.0.1
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:22.916
!MESSAGE Indexed 'freertos' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:26.669
!MESSAGE Indexed 'freertos_blinky' (12 sources, 104 headers) in 3.37 sec: 5,581 declarations; 11,848 references; 0 unresolved inclusions; 1 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:27.265
!MESSAGE Indexed 'lpc_board_nxp_lpcxpresso_824' (2 sources, 86 headers) in 0.588 sec: 4,022 declarations; 6,809 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:28.727
!MESSAGE Indexed 'lpc_chip_82x' (28 sources, 90 headers) in 1.44 sec: 4,467 declarations; 8,924 references; 0 unresolved inclusions; 1 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:29.213
!MESSAGE Indexed 'periph_acmp' (5 sources, 52 headers) in 0.462 sec: 3,120 declarations; 4,854 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:29.661
!MESSAGE Indexed 'periph_adc' (5 sources, 52 headers) in 0.436 sec: 3,127 declarations; 4,956 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:30.078
!MESSAGE Indexed 'periph_blinky' (5 sources, 52 headers) in 0.412 sec: 3,118 declarations; 4,803 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:30.531
!MESSAGE Indexed 'periph_bod' (5 sources, 52 headers) in 0.445 sec: 3,119 declarations; 4,822 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:30.897
!MESSAGE Indexed 'periph_clkout' (5 sources, 52 headers) in 0.351 sec: 3,123 declarations; 4,855 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:31.391
!MESSAGE Indexed 'periph_crc' (5 sources, 52 headers) in 0.484 sec: 3,125 declarations; 4,849 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:31.889
!MESSAGE Indexed 'periph_dma_mem' (5 sources, 55 headers) in 0.491 sec: 3,352 declarations; 5,160 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:32.277
!MESSAGE Indexed 'periph_dma_uart' (5 sources, 53 headers) in 0.375 sec: 3,228 declarations; 5,213 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:32.631
!MESSAGE Indexed 'periph_flashiap' (5 sources, 52 headers) in 0.344 sec: 3,134 declarations; 4,903 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:33.090
!MESSAGE Indexed 'periph_glitch_filter' (5 sources, 52 headers) in 0.452 sec: 3,125 declarations; 4,920 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:33.472
!MESSAGE Indexed 'periph_gpio' (5 sources, 52 headers) in 0.365 sec: 3,119 declarations; 4,826 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:33.861
!MESSAGE Indexed 'periph_hello_world' (5 sources, 52 headers) in 0.379 sec: 3,121 declarations; 4,835 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:34.403
!MESSAGE Indexed 'periph_i2c_rom_interrupt' (5 sources, 52 headers) in 0.533 sec: 3,164 declarations; 5,054 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:34.891
!MESSAGE Indexed 'periph_i2c_rom_polling' (5 sources, 52 headers) in 0.477 sec: 3,158 declarations; 5,025 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:35.262
!MESSAGE Indexed 'periph_i2c_rom_slave_interrupt' (5 sources, 52 headers) in 0.358 sec: 3,166 declarations; 5,067 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:35.671
!MESSAGE Indexed 'periph_i2cm_interrupt' (5 sources, 52 headers) in 0.403 sec: 3,147 declarations; 4,976 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:36.002
!MESSAGE Indexed 'periph_i2cm_polling' (5 sources, 52 headers) in 0.321 sec: 3,143 declarations; 4,946 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:36.430
!MESSAGE Indexed 'periph_i2cs_interrupt' (5 sources, 52 headers) in 0.421 sec: 3,191 declarations; 5,290 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:36.958
!MESSAGE Indexed 'periph_mrt' (5 sources, 52 headers) in 0.516 sec: 3,130 declarations; 4,871 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:37.408
!MESSAGE Indexed 'periph_pinint' (5 sources, 52 headers) in 0.43 sec: 3,118 declarations; 4,848 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:37.759
!MESSAGE Indexed 'periph_pll_tab' (5 sources, 53 headers) in 0.344 sec: 3,261 declarations; 4,992 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:38.138
!MESSAGE Indexed 'periph_pmu' (5 sources, 52 headers) in 0.365 sec: 3,125 declarations; 4,914 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:38.496
!MESSAGE Indexed 'periph_sct' (5 sources, 52 headers) in 0.348 sec: 3,121 declarations; 4,860 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:38.884
!MESSAGE Indexed 'periph_sct_pwm' (5 sources, 52 headers) in 0.38 sec: 3,125 declarations; 4,903 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:39.420
!MESSAGE Indexed 'periph_spi' (5 sources, 52 headers) in 0.519 sec: 3,132 declarations; 4,938 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:39.965
!MESSAGE Indexed 'periph_spi_sm_int' (5 sources, 53 headers) in 0.533 sec: 3,209 declarations; 5,210 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:40.378
!MESSAGE Indexed 'periph_systick' (5 sources, 52 headers) in 0.4 sec: 3,118 declarations; 4,803 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:40.713
!MESSAGE Indexed 'periph_uart' (5 sources, 52 headers) in 0.329 sec: 3,125 declarations; 4,844 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:41.150
!MESSAGE Indexed 'periph_uart_rb' (5 sources, 53 headers) in 0.43 sec: 3,208 declarations; 4,953 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:41.474
!MESSAGE Indexed 'periph_uart_rom_int' (5 sources, 53 headers) in 0.318 sec: 3,222 declarations; 5,014 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:41.908
!MESSAGE Indexed 'periph_uart_rom_polling' (5 sources, 53 headers) in 0.427 sec: 3,213 declarations; 4,982 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:42.208
!MESSAGE Indexed 'periph_wkt' (5 sources, 52 headers) in 0.292 sec: 3,126 declarations; 4,897 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:42.534
!MESSAGE Indexed 'periph_wwdt' (5 sources, 52 headers) in 0.319 sec: 3,120 declarations; 4,888 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:31:37.863
!MESSAGE Indexed 'NEW_TESTING_PROJECT' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 4 -1 2019-07-17 18:31:47.661
!MESSAGE The project 'NEW_TESTING_PROJECT' has no nature com.nxp.mcuxpresso.core.datamodels.sdkNature
!STACK 0
java.lang.Exception: org.eclipse.core.runtime.CoreException: The project 'NEW_TESTING_PROJECT' has no nature com.nxp.mcuxpresso.core.datamodels.sdkNature
at com.nxp.mcuxpresso.core.datamodels.providers.AddonsAdapterFactory.getAdapter(AddonsAdapterFactory.java:29)
at org.eclipse.core.internal.adapter.AdapterFactoryProxy.getAdapter(AdapterFactoryProxy.java:82)
at org.eclipse.core.internal.runtime.AdapterManager.getAdapter(AdapterManager.java:295)
at com.nxp.swtools.mcuxpressoide.adapter.MCUXpressoIDEAdapter.<init>(MCUXpressoIDEAdapter.java:53)
at com.nxp.swtools.mcuxpressoide.adapter.MCUXpressoIDEAdapterFactory.getAdapter(MCUXpressoIDEAdapterFactory.java:32)
at com.nxp.swtools.sdkproject.ToolchainProjectFactory.createToolchainProjectForImport(ToolchainProjectFactory.java:51)
at com.nxp.swtools.eclipse.handlers.OpenMexForProject.lambda$1(OpenMexForProject.java:123)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Caused by: org.eclipse.core.runtime.CoreException: The project 'NEW_TESTING_PROJECT' has no nature com.nxp.mcuxpresso.core.datamodels.sdkNature
at com.nxp.mcuxpresso.core.datamodels.providers.SDKComponentsHandler.internalRefresh(SDKComponentsHandler.java:105)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKComponentsHandler.<init>(SDKComponentsHandler.java:100)
at com.nxp.mcuxpresso.core.datamodels.providers.AddonsAdapterFactory.getAdapter(AddonsAdapterFactory.java:27)
... 9 more
!ENTRY com.nxp.swtools.eclipse.handlers 4 0 2019-07-17 18:31:47.722
!MESSAGE Eclipse Project not accessible. See Project Explorer, Problems View or Error Log for details
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.927
!MESSAGE Unable to find XML element for reference: armgcc (class com.nxp.mcuxpresso.core.datamodels.manifest.xml.ToolchainType)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.933
!MESSAGE Unable to find XML element for reference: iar (class com.nxp.mcuxpresso.core.datamodels.manifest.xml.ToolchainType)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.938
!MESSAGE Unable to find XML element for reference: mdk (class com.nxp.mcuxpresso.core.datamodels.manifest.xml.ToolchainType)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.943
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.948
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.953
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:33:45.573
!MESSAGE Indexed 'NEW_TESTINGS_hello_world' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.848
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.856
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.863
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.981
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.987
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.992
!ENTRY com.crt.log 1 0 2019-07-17 18:33:49.994
!ENTRY com.crt.log 1 0 2019-07-17 18:33:50.025
!ENTRY com.crt.log 1 0 2019-07-17 18:33:50.032
!ENTRY com.crt.log 1 0 2019-07-17 18:33:50.039
!ENTRY com.crt.log 1 0 2019-07-17 18:33:50.044
!ENTRY com.crt.log 1 0 2019-07-17 18:33:50.049
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:33:50.713
!MESSAGE Indexed 'NEW_TESTINGS_led_blinky' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.259
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.267
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.279
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.428
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.438
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.448
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.019
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.035
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.044
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.052
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.059
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.066
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:33:54.669
!MESSAGE Indexed 'NEW_TESTINGS_power_mode_switch_lpc' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.255
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.264
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.276
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.421
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.433
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.443
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.579
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.598
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.602
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.607
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.612
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.617
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:33:59.224
!MESSAGE Indexed 'NEW_TESTINGS_acomp_basic' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.739
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.758
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.766
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.891
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.896
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.901
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.821
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.840
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.848
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.857
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.861
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.866
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:03.512
!MESSAGE Indexed 'NEW_TESTINGS_acomp_interrupt' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:04.947
!ENTRY com.crt.log 1 0 2019-07-17 18:34:04.956
!ENTRY com.crt.log 1 0 2019-07-17 18:34:04.964
!ENTRY com.crt.log 1 0 2019-07-17 18:34:05.131
!ENTRY com.crt.log 1 0 2019-07-17 18:34:05.139
!ENTRY com.crt.log 1 0 2019-07-17 18:34:05.144
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.060
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.072
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.077
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.082
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.087
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.092
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:07.734
!MESSAGE Indexed 'NEW_TESTINGS_dma_channel_chain' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.314
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.322
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.327
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.434
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.438
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.443
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:09.448
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\dma\channel_chain\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.306
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.324
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.331
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.338
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.347
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.355
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:11.972
!MESSAGE Indexed 'NEW_TESTINGS_dma_interleave_transfer' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.188
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.202
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.215
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.415
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.420
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.425
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:13.430
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\dma\interleave_transfer\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.082
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.096
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.101
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.106
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.111
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.115
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:15.796
!MESSAGE Indexed 'NEW_TESTINGS_dma_linked_transfer' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.123
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.133
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.141
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.293
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.312
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.322
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:17.334
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\dma\linked_transfer\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.168
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.183
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.190
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.198
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.205
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.213
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:19.817
!MESSAGE Indexed 'NEW_TESTINGS_dma_memory_to_memory' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.253
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.259
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.264
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.387
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.393
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.398
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:21.403
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\dma\memory_to_memory\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.058
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.071
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.076
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.083
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.088
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.092
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:23.794
!MESSAGE Indexed 'NEW_TESTINGS_dma_wrap_transfer' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.489
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.499
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.511
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.725
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.730
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.735
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:25.741
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\dma\wrap_transfer\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.734
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.748
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.759
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.768
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.776
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.784
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:28.432
!MESSAGE Indexed 'NEW_TESTINGS_gpio_led_output' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.654
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.667
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.684
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.897
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.912
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.927
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.757
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.765
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.769
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.774
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.779
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.784
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:32.435
!MESSAGE Indexed 'NEW_TESTINGS_lpc_adc_basic' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.117
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.126
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.134
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.245
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.254
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.262
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.422
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.437
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.442
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.446
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.451
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.456
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:36.117
!MESSAGE Indexed 'NEW_TESTINGS_lpc_adc_burst' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.069
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.077
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.089
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.181
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.191
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.199
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.282
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.296
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.301
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.307
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.312
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.317
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:39.977
!MESSAGE Indexed 'NEW_TESTINGS_lpc_adc_dma' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:40.855
!ENTRY com.crt.log 1 0 2019-07-17 18:34:40.863
!ENTRY com.crt.log 1 0 2019-07-17 18:34:40.873
!ENTRY com.crt.log 1 0 2019-07-17 18:34:41.036
!ENTRY com.crt.log 1 0 2019-07-17 18:34:41.045
!ENTRY com.crt.log 1 0 2019-07-17 18:34:41.054
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:41.064
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\adc\lpc_adc_dma\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.023
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.038
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.044
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.049
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.054
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.058
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:43.712
!MESSAGE Indexed 'NEW_TESTINGS_lpc_adc_interrupt' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.451
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.460
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.469
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.644
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.652
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.660
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.659
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.665
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.670
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.676
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.682
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.686
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:47.410
!MESSAGE Indexed 'NEW_TESTINGS_lpc_i2c_dma_b2b_master' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.044
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.052
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.061
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.112
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.121
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.129
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.322
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.335
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.340
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.345
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.349
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.354
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:50.946
!MESSAGE Indexed 'NEW_TESTINGS_lpc_i2c_dma_b2b_slave' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.859
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.868
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.876
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.963
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.972
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.980
!ENTRY com.crt.log 1 0 2019-07-17 18:34:53.971
!ENTRY com.crt.log 1 0 2019-07-17 18:34:53.985
!ENTRY com.crt.log 1 0 2019-07-17 18:34:53.990
!ENTRY com.crt.log 1 0 2019-07-17 18:34:53.997
!ENTRY com.crt.log 1 0 2019-07-17 18:34:54.003
!ENTRY com.crt.log 1 0 2019-07-17 18:34:54.008
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:54.722
!MESSAGE Indexed 'NEW_TESTINGS_lpc_i2c_interrupt_b2b_transfer_master' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.411
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.420
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.428
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.521
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.532
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.540
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.472
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.485
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.490
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.495
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.501
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.506
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:58.085
!MESSAGE Indexed 'NEW_TESTINGS_lpc_i2c_interrupt_b2b_transfer_slave' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.856
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.864
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.872
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.957
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.966
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.975
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.812
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.843
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.847
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.853
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.933
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.938
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:35:01.666
!MESSAGE Indexed 'NEW_TESTINGS_lpc_i2c_polling_b2b_transfer_master' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.474
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.485
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.493
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.617
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.627
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.635
!SESSION 2019-07-17 18:36:32.438 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2019-07-17 18:36:43.631
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jface 2 0 2019-07-17 18:37:12.269
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2019-07-17 18:37:12.269
!MESSAGE A conflict occurred for CTRL+U:
Binding(CTRL+U,
ParameterizedCommand(Command(com.nxp.swtools.clocks.commands.unlockAll,Unlock All Settings,
Category(org.eclipse.core.commands.categories.autogenerated,Uncategorized,Commands that were either auto-generated or have no category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@f6d656,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(CTRL+U,
ParameterizedCommand(Command(org.eclipse.jdt.debug.ui.commands.Execute,Execute,
Evaluate selected text,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Debug command category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@cdf6e7,
,,true),null),
!ENTRY org.eclipse.ui 4 4 2019-07-17 18:37:15.671
!MESSAGE Plugin com.nxp.mcuxpresso.trace.core, extension org.eclipse.ui.decorators, id com.nxp.mcuxpresso.trace.core.decorator: Required sub element 'icon' not defined
!ENTRY org.eclipse.ui 4 4 2019-07-17 18:37:15.678
!MESSAGE Plugin com.nxp.mcuxpresso.trace.core, extension org.eclipse.ui.decorators, id com.nxp.mcuxpresso.trace.core.decorator: Unknown extension tag found: decorator
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2019-07-17 18:37:21.694
!MESSAGE Using manifest XSD 'manifest-schema/sdk_manifest_v3.4.xsd' for manifest 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\LPCXpresso824MAX_manifest_v3_4.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 2 0 2019-07-17 18:37:21.718
!MESSAGE The SDK manifest 'LPCXpresso824MAX_manifest_v3_4.xml' will be used. Please update your MCUXpresso IDE in order to get full SDK features.
!ENTRY org.eclipse.launchbar.core 2 0 2019-07-17 18:37:40.270
!MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY org.eclipse.launchbar.core 2 0 2019-07-17 18:37:40.307
!MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY org.eclipse.launchbar.core 2 0 2019-07-17 18:37:40.327
!ENTRY org.eclipse.egit.ui 2 0 2019-07-17 18:37:40.931
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\sabari'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2019-07-17 18:37:50.163
!MESSAGE HTTP Proxy Authentication Required: http://www.nxp.com/lgfiles/updates/Eclipse/mcuxpressoide/v10_3/content.xml
!STACK 1
org.eclipse.ecf.filetransfer.BrowseFileTransferException: Proxy Authentication Required
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:291)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
!SUBENTRY 1 org.eclipse.ecf.identity 4 0 2019-07-17 18:37:50.171
!MESSAGE Proxy Authentication Required
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2019-07-17 18:37:50.249
!MESSAGE HTTP Proxy Authentication Required: http://mcuxpresso.nxp.com/staticdata/updates/kex_ide_5.0/content.xml
!STACK 1
!SUBENTRY 1 org.eclipse.ecf.identity 4 0 2019-07-17 18:37:50.249
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2019-07-17 18:37:50.301
!MESSAGE HTTP Proxy Authentication Required: http://download.eclipse.org/releases/oxygen/compositeContent.xml
!STACK 1
!SUBENTRY 1 org.eclipse.ecf.identity 4 0 2019-07-17 18:37:50.301
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2019-07-17 18:37:50.331
!MESSAGE HTTP Proxy Authentication Required: http://www.pemicro.com/eclipse/updates/compositeContent.xml
!STACK 1
!SUBENTRY 1 org.eclipse.ecf.identity 4 0 2019-07-17 18:37:50.332
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2019-07-17 18:38:34.661
!MESSAGE Using manifest XSD 'manifest-schema/sdk_manifest_v3.3.xsd' for manifest 'C:\nxp\MCUXpressoIDE_10.3.1_2233\ide\plugins\com.nxp.mcuxpresso.core.datamodels.resources_10.3.0.201810041206\fragments\ksdk_manifest.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2019-07-17 18:38:34.676
!MESSAGE Using SDK manifest 'ksdk_manifest.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2019-07-17 18:38:35.128
!MESSAGE Using manifest XSD 'manifest-schema/sdk_manifest_v3.3.xsd' for manifest 'C:\nxp\MCUXpressoIDE_10.3.1_2233\ide\plugins\com.nxp.mcuxpresso.core.datamodels.resources_10.3.0.201810041206\override\override_manifest.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2019-07-17 18:38:35.138
!MESSAGE Using SDK manifest 'override_manifest.xml'.
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.169
!MESSAGE System property http.proxyHost is set to 172.54.16.201 but should not be set.
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.189
!MESSAGE System property http.proxyPort is set to 8080 but should not be set.
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.199
!MESSAGE System property https.proxyHost is set to 172.54.16.201 but should not be set.
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.209
!MESSAGE System property https.proxyPort is set to 8080 but should not be set.
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:42:59.219
!MESSAGE Error connecting to http://mcuxpresso.nxp.com/SWTools/npidb/processors/2/5.0?processor=LPC824 with error code 407
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:42:59.239
!MESSAGE [NETWORK] getProcessor - server not available or other error
!STACK 0
com.nxp.swtools.kex.exceptions.MfactServerError: Server error. Code=407 for http://mcuxpresso.nxp.com/SWTools/npidb/processors/2/5.0?processor=LPC824
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpBinaryResponse(HttpHelper.java:138)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpBinaryResponse(HttpHelper.java:162)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpGetBinaryResponse(HttpHelper.java:176)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpGetXmlResponse(HttpHelper.java:75)
at com.nxp.swtools.kex.api.internal.MfactApiClient.getProcessor(MfactApiClient.java:356)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.listProcessor(KExProcessorsProvider.java:292)
at com.nxp.swtools.utils.processors.ProcessorDataUpdateUI.updateAndGetProcessorStatus(ProcessorDataUpdateUI.java:82)
at com.nxp.swtools.sdkproject.ImportToolchainProjectFactory.importToolchainProject(ImportToolchainProjectFactory.java:305)
at com.nxp.swtools.eclipse.handlers.OpenMexForProject.lambda$1(OpenMexForProject.java:134)
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.279
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.289
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.299
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.309
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:42:59.319
!MESSAGE Error connecting to http://mcuxpresso.nxp.com/SWTools/npidb/components/2/5.0 with error code 407
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:42:59.329
!MESSAGE [NETWORK] listComponents - server not available or other error
!STACK 0
com.nxp.swtools.kex.exceptions.MfactServerError: Server error. Code=407 for http://mcuxpresso.nxp.com/SWTools/npidb/components/2/5.0
at com.nxp.swtools.kex.api.internal.MfactApiClient.listComponents(MfactApiClient.java:541)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.listComponents(KExProcessorsProvider.java:383)
at com.nxp.swtools.utils.processors.ProcessorDataUpdateUI.downloadOrUpdateComponents(ProcessorDataUpdateUI.java:302)
at com.nxp.swtools.sdkproject.ImportToolchainProjectFactory.importToolchainProject(ImportToolchainProjectFactory.java:307)
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 18:42:59.339
!MESSAGE Processor 'LPC824' is not supported or data for processor not available (check internet connection)
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.693
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.698
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.702
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.707
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:42:59.711
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:42:59.716
!STACK 0
at com.nxp.swtools.provider.processors.KExProcessorsProvider.listProcessor(KExProcessorsProvider.java:281)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.getProcessorMasterToolInfo(KExProcessorsProvider.java:1234)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.downloadOrUpdateProcessor(KExProcessorsProvider.java:543)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.checkOrDownloadProcessor(KExProcessorsProvider.java:578)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.checkOrDownloadCommonConfig(KExProcessorsProvider.java:794)
at com.nxp.swtools.utils.importer.PreparedImportStatus.preparePrjImport(PreparedImportStatus.java:137)
at com.nxp.swtools.sdkproject.ImportToolchainProjectFactory.lambda$1(ImportToolchainProjectFactory.java:139)
at java.util.LinkedHashMap$LinkedValues.forEach(LinkedHashMap.java:608)
at com.nxp.swtools.sdkproject.ImportToolchainProjectFactory.importSourcesFromProject(ImportToolchainProjectFactory.java:135)
at com.nxp.swtools.sdkproject.ImportToolchainProjectFactory.importToolchainProject(ImportToolchainProjectFactory.java:322)
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 18:42:59.725
!MESSAGE board\clock_config.c contains YAML but processor is not supported [SDK/DATA]
!ENTRY com.nxp.swtools.core 4 0 2019-07-17 18:42:59.812
!MESSAGE [SDK]/Data] Invalid coreID: core0. Could not set it for BOARD_InitPins function
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:43:00.557
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:43:00.562
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:43:00.571
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:43:00.575
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:43:00.581
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:43:00.585
!STACK 0
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 18:43:00.602
!MESSAGE board\pin_mux.c contains YAML but processor is not supported [SDK/DATA]
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 18:43:00.607
!MESSAGE [SDK] The project does not contain any configuration/source file to import
!ENTRY com.nxp.swtools.eclipse.handlers 4 0 2019-07-17 18:43:00.650
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.408
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.418
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.428
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:48:34.428
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:48:34.438
!STACK 0
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.438
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.448
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.458
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:48:34.458
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:48:34.468
!STACK 0
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 18:48:34.468
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.499
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.513
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.517
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.522
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:48:34.528
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:48:34.533
!STACK 0
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 18:48:34.538
!ENTRY com.nxp.swtools.core 4 0 2019-07-17 18:48:34.565
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.822
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.826
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.831
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.835
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:48:34.840
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:48:34.845
!STACK 0
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 18:48:34.850
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 18:48:34.856
!ENTRY com.nxp.swtools.eclipse.handlers 4 0 2019-07-17 18:48:34.898
!ENTRY com.crt.log 1 0 2019-07-17 19:02:43.769
!MESSAGE Trying to connect to redlink server on port 3025.
!ENTRY com.crt.debugcommon 1 0 2019-07-17 19:02:43.780
!MESSAGE RedlinkServer telnet session connected on port 3025->61207 @ 127.0.0.1
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:02:57.000
!MESSAGE Telnet session connected on port 3330->61213 @ 127.0.0.1
!ENTRY org.eclipse.tm.terminal.connector.cdtserial 4 0 2019-07-17 19:03:31.132
!MESSAGE Error setting DCB (31)
!STACK 0
java.io.IOException: Error setting DCB (31)
at org.eclipse.cdt.serial.SerialPort.open0(Native Method)
at org.eclipse.cdt.serial.SerialPort.open(SerialPort.java:312)
at org.eclipse.tm.terminal.connector.cdtserial.connector.SerialConnector.connect(SerialConnector.java:76)
at org.eclipse.tm.internal.terminal.connector.TerminalConnector.connect(TerminalConnector.java:158)
at org.eclipse.tm.internal.terminal.emulator.VT100TerminalControl.connectTerminal(VT100TerminalControl.java:440)
at org.eclipse.tm.terminal.view.ui.tabs.TabFolderManager.createTabItem(TabFolderManager.java:325)
at org.eclipse.tm.terminal.view.ui.manager.ConsoleManager.openConsole(ConsoleManager.java:472)
at org.eclipse.tm.terminal.view.ui.manager.ConsoleManager.openConsole(ConsoleManager.java:412)
at org.eclipse.tm.terminal.view.ui.services.TerminalService$3.doRun(TerminalService.java:313)
at org.eclipse.tm.terminal.view.ui.services.TerminalService$3$1.run(TerminalService.java:286)
!ENTRY org.eclipse.tm.terminal.connector.cdtserial 4 0 2019-07-17 19:03:38.750
!MESSAGE Error opening \\.\COM7 (5)
!STACK 0
java.io.IOException: Error opening \\.\COM7 (5)
!ENTRY org.eclipse.tm.terminal.connector.cdtserial 4 0 2019-07-17 19:03:49.225
!STACK 0
!ENTRY org.eclipse.tm.terminal.connector.cdtserial 4 0 2019-07-17 19:03:58.903
!STACK 0
!ENTRY com.crt.log 1 0 2019-07-17 19:04:21.121
!ENTRY com.crt.log 1 0 2019-07-17 19:04:31.128
!MESSAGE Trying to connect to redlink server on port 3050.
!ENTRY com.crt.debugcommon 4 0 2019-07-17 19:04:31.228
!MESSAGE RedlinkServer Telnet session connection timeout expired.
!ENTRY com.crt.log 1 0 2019-07-17 19:04:41.138
!MESSAGE Trying to connect to redlink server on port 3075.
!ENTRY com.crt.debugcommon 4 0 2019-07-17 19:04:41.288
!ENTRY com.crt.debugcommon 4 0 2019-07-17 19:04:51.228
!ENTRY com.crt.log 1 0 2019-07-17 19:04:54.418
!ENTRY com.crt.debugcommon 1 0 2019-07-17 19:04:54.438
!MESSAGE RedlinkServer telnet session connected on port 3025->61253 @ 127.0.0.1
!ENTRY org.eclipse.cdt.dsf 4 10005 2019-07-17 19:04:55.283
!MESSAGE Request for monitor: '[Lorg.eclipse.cdt.dsf.debug.service.IRunControl$IContainerDMContext;@1fe8a00' resulted in a rejected execution exception.
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:04:55.283
!MESSAGE Exception logged
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@134e2e1 rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
at java.util.concurrent.ScheduledThreadPoolExecutor.execute(ScheduledThreadPoolExecutor.java:622)
at org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor.execute(DefaultDsfExecutor.java:462)
at org.eclipse.cdt.dsf.gdb.internal.ui.actions.DsfTerminateCommand.canExecute(DsfTerminateCommand.java:94)
at com.crt.dsfdebug.dsf.override.commands.CRTDsfTerminateCommand.canExecute(CRTDsfTerminateCommand.java:85)
!ENTRY org.eclipse.debug.ui 4 2 2019-07-17 19:04:55.293
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.debug.ui".
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@1acfc7c rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
at org.eclipse.cdt.dsf.debug.ui.actions.DsfResumeCommand.canExecuteSingle(DsfResumeCommand.java:79)
at org.eclipse.cdt.dsf.debug.ui.actions.DsfResumeCommand.canExecute(DsfResumeCommand.java:49)
!ENTRY org.eclipse.debug.ui 4 120 2019-07-17 19:04:55.293
!STACK 0
!ENTRY org.eclipse.cdt.dsf 4 10005 2019-07-17 19:04:55.303
!MESSAGE Request for monitor: '[Lorg.eclipse.cdt.dsf.debug.service.IRunControl$IContainerDMContext;@12f0fa6' resulted in a rejected execution exception.
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:04:55.313
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@8960cb rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 2 2019-07-17 19:04:55.313
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@ea5707 rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 120 2019-07-17 19:04:55.323
!STACK 0
!ENTRY org.eclipse.cdt.dsf 4 10005 2019-07-17 19:04:55.323
!MESSAGE Request for monitor: '[Lorg.eclipse.cdt.dsf.debug.service.IRunControl$IContainerDMContext;@1902ccf' resulted in a rejected execution exception.
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:04:55.333
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@c5b04b rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 2 2019-07-17 19:04:55.333
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@1b7e9c3 rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 120 2019-07-17 19:04:55.343
!STACK 0
!ENTRY org.eclipse.cdt.dsf 4 10005 2019-07-17 19:04:55.353
!MESSAGE Request for monitor: '[Lorg.eclipse.cdt.dsf.debug.service.IRunControl$IContainerDMContext;@508b3d' resulted in a rejected execution exception.
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:04:55.353
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@151f6f3 rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 2 2019-07-17 19:04:55.363
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@6f91cc rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 120 2019-07-17 19:04:55.363
!STACK 0
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:04:59.298
!MESSAGE Telnet session connected on port 3330->61258 @ 127.0.0.1
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.329
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.339
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.346
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.352
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 19:05:21.359
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 19:05:21.366
!STACK 0
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.378
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.388
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.394
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.400
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 19:05:21.407
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 19:05:21.414
!STACK 0
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 19:05:21.421
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.455
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.464
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.473
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.479
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 19:05:21.485
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 19:05:21.492
!STACK 0
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 19:05:21.500
!ENTRY com.nxp.swtools.core 4 0 2019-07-17 19:05:21.544
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:22.058
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:22.067
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:22.073
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:22.080
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 19:05:22.086
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 19:05:22.092
!STACK 0
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 19:05:22.099
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 19:05:22.107
!ENTRY com.nxp.swtools.eclipse.handlers 4 0 2019-07-17 19:05:22.223
!SESSION 2019-07-17 11:06:14.729 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_181
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_IN
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file C:\Users\sabari\Documents\MCUXpressoIDE_10.3.1_2233\workspace\.metadata\.bak_1.log
Created Time: 2019-07-17 18:24:03.349
!ENTRY org.eclipse.debug.ui 4 120 2019-07-17 18:24:03.349
!MESSAGE Error logged from Debug UI:
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@1ecb6c0 rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@1b930b5[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 9057]
at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2063)
at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:830)
at java.util.concurrent.ScheduledThreadPoolExecutor.delayedExecute(ScheduledThreadPoolExecutor.java:326)
at java.util.concurrent.ScheduledThreadPoolExecutor.schedule(ScheduledThreadPoolExecutor.java:533)
at org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor.schedule(DefaultDsfExecutor.java:438)
at java.util.concurrent.ScheduledThreadPoolExecutor.submit(ScheduledThreadPoolExecutor.java:632)
at org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor.submit(DefaultDsfExecutor.java:470)
at org.eclipse.cdt.dsf.debug.ui.actions.DsfStepReturnCommand.canExecute(DsfStepReturnCommand.java:53)
at org.eclipse.debug.internal.ui.commands.actions.DebugCommandService.updateCommand(DebugCommandService.java:178)
at org.eclipse.debug.internal.ui.commands.actions.DebugCommandService.postUpdate(DebugCommandService.java:153)
at org.eclipse.debug.internal.ui.commands.actions.DebugCommandService.debugContextChanged(DebugCommandService.java:234)
at org.eclipse.debug.internal.ui.contexts.DebugWindowContextService$2.run(DebugWindowContextService.java:231)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.debug.internal.ui.contexts.DebugWindowContextService.notify(DebugWindowContextService.java:228)
at org.eclipse.debug.internal.ui.contexts.DebugWindowContextService.notify(DebugWindowContextService.java:212)
at org.eclipse.debug.internal.ui.contexts.DebugWindowContextService.debugContextChanged(DebugWindowContextService.java:452)
at org.eclipse.debug.ui.contexts.AbstractDebugContextProvider$1.run(AbstractDebugContextProvider.java:82)
at org.eclipse.debug.ui.contexts.AbstractDebugContextProvider.fire(AbstractDebugContextProvider.java:79)
at org.eclipse.debug.internal.ui.views.launch.LaunchView$ContextProviderProxy.debugContextChanged(LaunchView.java:519)
at org.eclipse.debug.internal.ui.views.launch.LaunchView$TreeViewerContextProvider.possibleChange(LaunchView.java:405)
at org.eclipse.debug.internal.ui.views.launch.LaunchView$TreeViewerContextProvider$Visitor.visit(LaunchView.java:327)
at org.eclipse.cdt.dsf.ui.viewmodel.VMDelta.doAccept(VMDelta.java:365)
at org.eclipse.cdt.dsf.ui.viewmodel.VMDelta.doAccept(VMDelta.java:368)
at org.eclipse.cdt.dsf.ui.viewmodel.VMDelta.accept(VMDelta.java:360)
at org.eclipse.debug.internal.ui.views.launch.LaunchView$TreeViewerContextProvider.modelChanged(LaunchView.java:435)
at org.eclipse.debug.internal.ui.viewers.model.TreeModelContentProvider.doModelChanged(TreeModelContentProvider.java:431)
at org.eclipse.debug.internal.ui.viewers.model.TreeModelContentProvider.modelChanged(TreeModelContentProvider.java:400)
at org.eclipse.cdt.dsf.ui.viewmodel.DefaultVMModelProxyStrategy$1.run(DefaultVMModelProxyStrategy.java:155)
at org.eclipse.cdt.dsf.ui.viewmodel.DefaultVMModelProxyStrategy.fireModelChanged(DefaultVMModelProxyStrategy.java:159)
at org.eclipse.cdt.dsf.ui.viewmodel.update.AbstractCachingVMProvider$6.handleSuccess(AbstractCachingVMProvider.java:898)
at org.eclipse.cdt.dsf.concurrent.RequestMonitor.handleCompleted(RequestMonitor.java:385)
at org.eclipse.cdt.dsf.concurrent.RequestMonitor$2.run(RequestMonitor.java:312)
at org.eclipse.cdt.dsf.ui.concurrent.SimpleDisplayExecutor.runInSwtThread(SimpleDisplayExecutor.java:117)
at org.eclipse.cdt.dsf.ui.concurrent.SimpleDisplayExecutor$1.run(SimpleDisplayExecutor.java:80)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:37)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4213)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3820)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
!ENTRY com.crt.log 4 -1 2019-07-17 18:24:03.524
!MESSAGE Document is closed
!STACK 0
java.lang.Exception: java.io.IOException: Document is closed
at com.crt.utils.general.Reporter.log(Reporter.java:654)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.log(MCXTelnetService.java:418)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.shutdown(MCXTelnetService.java:197)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.launchesTerminated(MCXTelnetService.java:283)
at org.eclipse.debug.internal.core.LaunchManager$LaunchesNotifier.run(LaunchManager.java:314)
at org.eclipse.debug.internal.core.LaunchManager$LaunchesNotifier.notify(LaunchManager.java:266)
at org.eclipse.debug.internal.core.LaunchManager.fireUpdate(LaunchManager.java:1054)
at org.eclipse.debug.core.Launch.fireTerminate(Launch.java:479)
at org.eclipse.cdt.dsf.debug.model.DsfLaunch.access$1(DsfLaunch.java:1)
at org.eclipse.cdt.dsf.debug.model.DsfLaunch$2.run(DsfLaunch.java:52)
at org.eclipse.debug.core.DebugPlugin$AsynchRunner.run(DebugPlugin.java:1110)
at org.eclipse.debug.core.DebugPlugin$AsynchRunner.async(DebugPlugin.java:1091)
at org.eclipse.debug.core.DebugPlugin$EventDispatchJob.run(DebugPlugin.java:440)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
Caused by: java.io.IOException: Document is closed
at org.eclipse.ui.internal.console.IOConsolePartitioner.streamAppended(IOConsolePartitioner.java:462)
at org.eclipse.ui.console.IOConsoleOutputStream.notifyParitioner(IOConsoleOutputStream.java:295)
at org.eclipse.ui.console.IOConsoleOutputStream.encodedWrite(IOConsoleOutputStream.java:290)
at org.eclipse.ui.console.IOConsoleOutputStream.write(IOConsoleOutputStream.java:274)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.log(MCXTelnetService.java:412)
... 14 more
!ENTRY com.crt.log 4 -1 2019-07-17 18:24:03.529
!STACK 0
at com.crt.dsfdebug.dsf.services.MCXTelnetService.lf(MCXTelnetService.java:451)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.shutdown(MCXTelnetService.java:196)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.launchesRemoved(MCXTelnetService.java:215)
at org.eclipse.debug.internal.core.LaunchManager$LaunchesNotifier.run(LaunchManager.java:283)
at org.eclipse.debug.internal.core.LaunchManager.removeLaunch(LaunchManager.java:2245)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationManager.removeTerminatedLaunches(LaunchConfigurationManager.java:330)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchConfigurationManager.launchAdded(LaunchConfigurationManager.java:316)
at org.eclipse.debug.internal.core.LaunchManager$LaunchNotifier.run(LaunchManager.java:446)
at org.eclipse.debug.internal.core.LaunchManager$LaunchNotifier.notify(LaunchManager.java:433)
at org.eclipse.debug.internal.core.LaunchManager.fireUpdate(LaunchManager.java:1043)
at org.eclipse.debug.internal.core.LaunchManager.addLaunch(LaunchManager.java:703)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:834)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:739)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1039)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1256)
at org.eclipse.ui.console.IOConsoleOutputStream.close(IOConsoleOutputStream.java:179)
at org.eclipse.ui.console.IOConsoleOutputStream.notifyParitioner(IOConsoleOutputStream.java:304)
at org.eclipse.ui.console.IOConsoleOutputStream.write(IOConsoleOutputStream.java:209)
at org.eclipse.ui.console.IOConsoleOutputStream.write(IOConsoleOutputStream.java:225)
at com.crt.dsfdebug.dsf.services.MCXTelnetService.lf(MCXTelnetService.java:442)
... 20 more
!ENTRY com.crt.log 4 -1 2019-07-17 18:24:03.554
!STACK 0
... 20 more
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 18:24:09.238
!MESSAGE Telnet session connected on port 3332->60506 @ 127.0.0.1
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:22.916
!MESSAGE Indexed 'freertos' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:26.669
!MESSAGE Indexed 'freertos_blinky' (12 sources, 104 headers) in 3.37 sec: 5,581 declarations; 11,848 references; 0 unresolved inclusions; 1 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:27.265
!MESSAGE Indexed 'lpc_board_nxp_lpcxpresso_824' (2 sources, 86 headers) in 0.588 sec: 4,022 declarations; 6,809 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:28.727
!MESSAGE Indexed 'lpc_chip_82x' (28 sources, 90 headers) in 1.44 sec: 4,467 declarations; 8,924 references; 0 unresolved inclusions; 1 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:29.213
!MESSAGE Indexed 'periph_acmp' (5 sources, 52 headers) in 0.462 sec: 3,120 declarations; 4,854 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:29.661
!MESSAGE Indexed 'periph_adc' (5 sources, 52 headers) in 0.436 sec: 3,127 declarations; 4,956 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:30.078
!MESSAGE Indexed 'periph_blinky' (5 sources, 52 headers) in 0.412 sec: 3,118 declarations; 4,803 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:30.531
!MESSAGE Indexed 'periph_bod' (5 sources, 52 headers) in 0.445 sec: 3,119 declarations; 4,822 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:30.897
!MESSAGE Indexed 'periph_clkout' (5 sources, 52 headers) in 0.351 sec: 3,123 declarations; 4,855 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:31.391
!MESSAGE Indexed 'periph_crc' (5 sources, 52 headers) in 0.484 sec: 3,125 declarations; 4,849 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:31.889
!MESSAGE Indexed 'periph_dma_mem' (5 sources, 55 headers) in 0.491 sec: 3,352 declarations; 5,160 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:32.277
!MESSAGE Indexed 'periph_dma_uart' (5 sources, 53 headers) in 0.375 sec: 3,228 declarations; 5,213 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:32.631
!MESSAGE Indexed 'periph_flashiap' (5 sources, 52 headers) in 0.344 sec: 3,134 declarations; 4,903 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:33.090
!MESSAGE Indexed 'periph_glitch_filter' (5 sources, 52 headers) in 0.452 sec: 3,125 declarations; 4,920 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:33.472
!MESSAGE Indexed 'periph_gpio' (5 sources, 52 headers) in 0.365 sec: 3,119 declarations; 4,826 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:33.861
!MESSAGE Indexed 'periph_hello_world' (5 sources, 52 headers) in 0.379 sec: 3,121 declarations; 4,835 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:34.403
!MESSAGE Indexed 'periph_i2c_rom_interrupt' (5 sources, 52 headers) in 0.533 sec: 3,164 declarations; 5,054 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:34.891
!MESSAGE Indexed 'periph_i2c_rom_polling' (5 sources, 52 headers) in 0.477 sec: 3,158 declarations; 5,025 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:35.262
!MESSAGE Indexed 'periph_i2c_rom_slave_interrupt' (5 sources, 52 headers) in 0.358 sec: 3,166 declarations; 5,067 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:35.671
!MESSAGE Indexed 'periph_i2cm_interrupt' (5 sources, 52 headers) in 0.403 sec: 3,147 declarations; 4,976 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:36.002
!MESSAGE Indexed 'periph_i2cm_polling' (5 sources, 52 headers) in 0.321 sec: 3,143 declarations; 4,946 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:36.430
!MESSAGE Indexed 'periph_i2cs_interrupt' (5 sources, 52 headers) in 0.421 sec: 3,191 declarations; 5,290 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:36.958
!MESSAGE Indexed 'periph_mrt' (5 sources, 52 headers) in 0.516 sec: 3,130 declarations; 4,871 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:37.408
!MESSAGE Indexed 'periph_pinint' (5 sources, 52 headers) in 0.43 sec: 3,118 declarations; 4,848 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:37.759
!MESSAGE Indexed 'periph_pll_tab' (5 sources, 53 headers) in 0.344 sec: 3,261 declarations; 4,992 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:38.138
!MESSAGE Indexed 'periph_pmu' (5 sources, 52 headers) in 0.365 sec: 3,125 declarations; 4,914 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:38.496
!MESSAGE Indexed 'periph_sct' (5 sources, 52 headers) in 0.348 sec: 3,121 declarations; 4,860 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:38.884
!MESSAGE Indexed 'periph_sct_pwm' (5 sources, 52 headers) in 0.38 sec: 3,125 declarations; 4,903 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:39.420
!MESSAGE Indexed 'periph_spi' (5 sources, 52 headers) in 0.519 sec: 3,132 declarations; 4,938 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:39.965
!MESSAGE Indexed 'periph_spi_sm_int' (5 sources, 53 headers) in 0.533 sec: 3,209 declarations; 5,210 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:40.378
!MESSAGE Indexed 'periph_systick' (5 sources, 52 headers) in 0.4 sec: 3,118 declarations; 4,803 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:40.713
!MESSAGE Indexed 'periph_uart' (5 sources, 52 headers) in 0.329 sec: 3,125 declarations; 4,844 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:41.150
!MESSAGE Indexed 'periph_uart_rb' (5 sources, 53 headers) in 0.43 sec: 3,208 declarations; 4,953 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:41.474
!MESSAGE Indexed 'periph_uart_rom_int' (5 sources, 53 headers) in 0.318 sec: 3,222 declarations; 5,014 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:41.908
!MESSAGE Indexed 'periph_uart_rom_polling' (5 sources, 53 headers) in 0.427 sec: 3,213 declarations; 4,982 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:42.208
!MESSAGE Indexed 'periph_wkt' (5 sources, 52 headers) in 0.292 sec: 3,126 declarations; 4,897 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:29:42.534
!MESSAGE Indexed 'periph_wwdt' (5 sources, 52 headers) in 0.319 sec: 3,120 declarations; 4,888 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:31:37.863
!MESSAGE Indexed 'NEW_TESTING_PROJECT' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 4 -1 2019-07-17 18:31:47.661
!MESSAGE The project 'NEW_TESTING_PROJECT' has no nature com.nxp.mcuxpresso.core.datamodels.sdkNature
!STACK 0
java.lang.Exception: org.eclipse.core.runtime.CoreException: The project 'NEW_TESTING_PROJECT' has no nature com.nxp.mcuxpresso.core.datamodels.sdkNature
at com.nxp.mcuxpresso.core.datamodels.providers.AddonsAdapterFactory.getAdapter(AddonsAdapterFactory.java:29)
at org.eclipse.core.internal.adapter.AdapterFactoryProxy.getAdapter(AdapterFactoryProxy.java:82)
at org.eclipse.core.internal.runtime.AdapterManager.getAdapter(AdapterManager.java:295)
at com.nxp.swtools.mcuxpressoide.adapter.MCUXpressoIDEAdapter.<init>(MCUXpressoIDEAdapter.java:53)
at com.nxp.swtools.mcuxpressoide.adapter.MCUXpressoIDEAdapterFactory.getAdapter(MCUXpressoIDEAdapterFactory.java:32)
at com.nxp.swtools.sdkproject.ToolchainProjectFactory.createToolchainProjectForImport(ToolchainProjectFactory.java:51)
at com.nxp.swtools.eclipse.handlers.OpenMexForProject.lambda$1(OpenMexForProject.java:123)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Caused by: org.eclipse.core.runtime.CoreException: The project 'NEW_TESTING_PROJECT' has no nature com.nxp.mcuxpresso.core.datamodels.sdkNature
at com.nxp.mcuxpresso.core.datamodels.providers.SDKComponentsHandler.internalRefresh(SDKComponentsHandler.java:105)
at com.nxp.mcuxpresso.core.datamodels.providers.SDKComponentsHandler.<init>(SDKComponentsHandler.java:100)
at com.nxp.mcuxpresso.core.datamodels.providers.AddonsAdapterFactory.getAdapter(AddonsAdapterFactory.java:27)
... 9 more
!ENTRY com.nxp.swtools.eclipse.handlers 4 0 2019-07-17 18:31:47.722
!MESSAGE Eclipse Project not accessible. See Project Explorer, Problems View or Error Log for details
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.927
!MESSAGE Unable to find XML element for reference: armgcc (class com.nxp.mcuxpresso.core.datamodels.manifest.xml.ToolchainType)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.933
!MESSAGE Unable to find XML element for reference: iar (class com.nxp.mcuxpresso.core.datamodels.manifest.xml.ToolchainType)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.938
!MESSAGE Unable to find XML element for reference: mdk (class com.nxp.mcuxpresso.core.datamodels.manifest.xml.ToolchainType)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.943
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.948
!ENTRY com.crt.log 1 0 2019-07-17 18:33:44.953
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:33:45.573
!MESSAGE Indexed 'NEW_TESTINGS_hello_world' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.848
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.856
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.863
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.981
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.987
!ENTRY com.crt.log 1 0 2019-07-17 18:33:47.992
!ENTRY com.crt.log 1 0 2019-07-17 18:33:49.994
!ENTRY com.crt.log 1 0 2019-07-17 18:33:50.025
!ENTRY com.crt.log 1 0 2019-07-17 18:33:50.032
!ENTRY com.crt.log 1 0 2019-07-17 18:33:50.039
!ENTRY com.crt.log 1 0 2019-07-17 18:33:50.044
!ENTRY com.crt.log 1 0 2019-07-17 18:33:50.049
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:33:50.713
!MESSAGE Indexed 'NEW_TESTINGS_led_blinky' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.259
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.267
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.279
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.428
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.438
!ENTRY com.crt.log 1 0 2019-07-17 18:33:51.448
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.019
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.035
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.044
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.052
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.059
!ENTRY com.crt.log 1 0 2019-07-17 18:33:54.066
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:33:54.669
!MESSAGE Indexed 'NEW_TESTINGS_power_mode_switch_lpc' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.255
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.264
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.276
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.421
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.433
!ENTRY com.crt.log 1 0 2019-07-17 18:33:56.443
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.579
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.598
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.602
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.607
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.612
!ENTRY com.crt.log 1 0 2019-07-17 18:33:58.617
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:33:59.224
!MESSAGE Indexed 'NEW_TESTINGS_acomp_basic' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.739
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.758
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.766
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.891
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.896
!ENTRY com.crt.log 1 0 2019-07-17 18:34:00.901
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.821
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.840
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.848
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.857
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.861
!ENTRY com.crt.log 1 0 2019-07-17 18:34:02.866
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:03.512
!MESSAGE Indexed 'NEW_TESTINGS_acomp_interrupt' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:04.947
!ENTRY com.crt.log 1 0 2019-07-17 18:34:04.956
!ENTRY com.crt.log 1 0 2019-07-17 18:34:04.964
!ENTRY com.crt.log 1 0 2019-07-17 18:34:05.131
!ENTRY com.crt.log 1 0 2019-07-17 18:34:05.139
!ENTRY com.crt.log 1 0 2019-07-17 18:34:05.144
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.060
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.072
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.077
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.082
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.087
!ENTRY com.crt.log 1 0 2019-07-17 18:34:07.092
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:07.734
!MESSAGE Indexed 'NEW_TESTINGS_dma_channel_chain' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.314
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.322
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.327
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.434
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.438
!ENTRY com.crt.log 1 0 2019-07-17 18:34:09.443
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:09.448
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\dma\channel_chain\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.306
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.324
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.331
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.338
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.347
!ENTRY com.crt.log 1 0 2019-07-17 18:34:11.355
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:11.972
!MESSAGE Indexed 'NEW_TESTINGS_dma_interleave_transfer' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.188
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.202
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.215
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.415
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.420
!ENTRY com.crt.log 1 0 2019-07-17 18:34:13.425
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:13.430
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\dma\interleave_transfer\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.082
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.096
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.101
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.106
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.111
!ENTRY com.crt.log 1 0 2019-07-17 18:34:15.115
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:15.796
!MESSAGE Indexed 'NEW_TESTINGS_dma_linked_transfer' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.123
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.133
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.141
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.293
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.312
!ENTRY com.crt.log 1 0 2019-07-17 18:34:17.322
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:17.334
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\dma\linked_transfer\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.168
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.183
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.190
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.198
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.205
!ENTRY com.crt.log 1 0 2019-07-17 18:34:19.213
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:19.817
!MESSAGE Indexed 'NEW_TESTINGS_dma_memory_to_memory' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.253
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.259
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.264
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.387
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.393
!ENTRY com.crt.log 1 0 2019-07-17 18:34:21.398
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:21.403
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\dma\memory_to_memory\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.058
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.071
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.076
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.083
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.088
!ENTRY com.crt.log 1 0 2019-07-17 18:34:23.092
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:23.794
!MESSAGE Indexed 'NEW_TESTINGS_dma_wrap_transfer' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.489
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.499
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.511
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.725
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.730
!ENTRY com.crt.log 1 0 2019-07-17 18:34:25.735
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:25.741
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\dma\wrap_transfer\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.734
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.748
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.759
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.768
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.776
!ENTRY com.crt.log 1 0 2019-07-17 18:34:27.784
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:28.432
!MESSAGE Indexed 'NEW_TESTINGS_gpio_led_output' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.654
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.667
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.684
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.897
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.912
!ENTRY com.crt.log 1 0 2019-07-17 18:34:29.927
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.757
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.765
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.769
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.774
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.779
!ENTRY com.crt.log 1 0 2019-07-17 18:34:31.784
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:32.435
!MESSAGE Indexed 'NEW_TESTINGS_lpc_adc_basic' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.117
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.126
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.134
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.245
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.254
!ENTRY com.crt.log 1 0 2019-07-17 18:34:33.262
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.422
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.437
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.442
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.446
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.451
!ENTRY com.crt.log 1 0 2019-07-17 18:34:35.456
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:36.117
!MESSAGE Indexed 'NEW_TESTINGS_lpc_adc_burst' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.069
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.077
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.089
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.181
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.191
!ENTRY com.crt.log 1 0 2019-07-17 18:34:37.199
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.282
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.296
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.301
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.307
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.312
!ENTRY com.crt.log 1 0 2019-07-17 18:34:39.317
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:39.977
!MESSAGE Indexed 'NEW_TESTINGS_lpc_adc_dma' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:40.855
!ENTRY com.crt.log 1 0 2019-07-17 18:34:40.863
!ENTRY com.crt.log 1 0 2019-07-17 18:34:40.873
!ENTRY com.crt.log 1 0 2019-07-17 18:34:41.036
!ENTRY com.crt.log 1 0 2019-07-17 18:34:41.045
!ENTRY com.crt.log 1 0 2019-07-17 18:34:41.054
!ENTRY com.nxp.mcuxpresso.core.datamodels 4 0 2019-07-17 18:34:41.064
!MESSAGE The file 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\boards\lpcxpresso824max\driver_examples\adc\lpc_adc_dma\readme.txt' does not exist in the SDK.
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.023
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.038
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.044
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.049
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.054
!ENTRY com.crt.log 1 0 2019-07-17 18:34:43.058
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:43.712
!MESSAGE Indexed 'NEW_TESTINGS_lpc_adc_interrupt' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.451
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.460
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.469
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.644
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.652
!ENTRY com.crt.log 1 0 2019-07-17 18:34:44.660
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.659
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.665
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.670
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.676
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.682
!ENTRY com.crt.log 1 0 2019-07-17 18:34:46.686
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:47.410
!MESSAGE Indexed 'NEW_TESTINGS_lpc_i2c_dma_b2b_master' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.044
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.052
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.061
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.112
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.121
!ENTRY com.crt.log 1 0 2019-07-17 18:34:48.129
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.322
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.335
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.340
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.345
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.349
!ENTRY com.crt.log 1 0 2019-07-17 18:34:50.354
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:50.946
!MESSAGE Indexed 'NEW_TESTINGS_lpc_i2c_dma_b2b_slave' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.859
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.868
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.876
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.963
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.972
!ENTRY com.crt.log 1 0 2019-07-17 18:34:51.980
!ENTRY com.crt.log 1 0 2019-07-17 18:34:53.971
!ENTRY com.crt.log 1 0 2019-07-17 18:34:53.985
!ENTRY com.crt.log 1 0 2019-07-17 18:34:53.990
!ENTRY com.crt.log 1 0 2019-07-17 18:34:53.997
!ENTRY com.crt.log 1 0 2019-07-17 18:34:54.003
!ENTRY com.crt.log 1 0 2019-07-17 18:34:54.008
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:54.722
!MESSAGE Indexed 'NEW_TESTINGS_lpc_i2c_interrupt_b2b_transfer_master' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.411
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.420
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.428
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.521
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.532
!ENTRY com.crt.log 1 0 2019-07-17 18:34:55.540
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.472
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.485
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.490
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.495
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.501
!ENTRY com.crt.log 1 0 2019-07-17 18:34:57.506
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:34:58.085
!MESSAGE Indexed 'NEW_TESTINGS_lpc_i2c_interrupt_b2b_transfer_slave' (0 sources, 0 headers) in 0 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.856
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.864
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.872
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.957
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.966
!ENTRY com.crt.log 1 0 2019-07-17 18:34:58.975
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.812
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.843
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.847
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.853
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.933
!ENTRY com.crt.log 1 0 2019-07-17 18:35:00.938
!ENTRY org.eclipse.cdt.core 1 0 2019-07-17 18:35:01.666
!MESSAGE Indexed 'NEW_TESTINGS_lpc_i2c_polling_b2b_transfer_master' (0 sources, 0 headers) in 0.001 sec: 0 declarations; 0 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.474
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.485
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.493
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.617
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.627
!ENTRY com.crt.log 1 0 2019-07-17 18:35:02.635
!SESSION 2019-07-17 18:36:32.438 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2019-07-17 18:36:43.631
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jface 2 0 2019-07-17 18:37:12.269
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2019-07-17 18:37:12.269
!MESSAGE A conflict occurred for CTRL+U:
Binding(CTRL+U,
ParameterizedCommand(Command(com.nxp.swtools.clocks.commands.unlockAll,Unlock All Settings,
Category(org.eclipse.core.commands.categories.autogenerated,Uncategorized,Commands that were either auto-generated or have no category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@f6d656,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(CTRL+U,
ParameterizedCommand(Command(org.eclipse.jdt.debug.ui.commands.Execute,Execute,
Evaluate selected text,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Debug command category,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@cdf6e7,
,,true),null),
!ENTRY org.eclipse.ui 4 4 2019-07-17 18:37:15.671
!MESSAGE Plugin com.nxp.mcuxpresso.trace.core, extension org.eclipse.ui.decorators, id com.nxp.mcuxpresso.trace.core.decorator: Required sub element 'icon' not defined
!ENTRY org.eclipse.ui 4 4 2019-07-17 18:37:15.678
!MESSAGE Plugin com.nxp.mcuxpresso.trace.core, extension org.eclipse.ui.decorators, id com.nxp.mcuxpresso.trace.core.decorator: Unknown extension tag found: decorator
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2019-07-17 18:37:21.694
!MESSAGE Using manifest XSD 'manifest-schema/sdk_manifest_v3.4.xsd' for manifest 'C:\Users\sabari\mcuxpresso\01\SDKPackages\SDK_2.6.0_LPCXpresso824MAX\LPCXpresso824MAX_manifest_v3_4.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 2 0 2019-07-17 18:37:21.718
!MESSAGE The SDK manifest 'LPCXpresso824MAX_manifest_v3_4.xml' will be used. Please update your MCUXpresso IDE in order to get full SDK features.
!ENTRY org.eclipse.launchbar.core 2 0 2019-07-17 18:37:40.270
!MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY org.eclipse.launchbar.core 2 0 2019-07-17 18:37:40.307
!MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType
!ENTRY org.eclipse.launchbar.core 2 0 2019-07-17 18:37:40.327
!ENTRY org.eclipse.egit.ui 2 0 2019-07-17 18:37:40.931
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\sabari'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2019-07-17 18:37:50.163
!MESSAGE HTTP Proxy Authentication Required: http://www.nxp.com/lgfiles/updates/Eclipse/mcuxpressoide/v10_3/content.xml
!STACK 1
org.eclipse.ecf.filetransfer.BrowseFileTransferException: Proxy Authentication Required
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:291)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
!SUBENTRY 1 org.eclipse.ecf.identity 4 0 2019-07-17 18:37:50.171
!MESSAGE Proxy Authentication Required
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2019-07-17 18:37:50.249
!MESSAGE HTTP Proxy Authentication Required: http://mcuxpresso.nxp.com/staticdata/updates/kex_ide_5.0/content.xml
!STACK 1
!SUBENTRY 1 org.eclipse.ecf.identity 4 0 2019-07-17 18:37:50.249
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2019-07-17 18:37:50.301
!MESSAGE HTTP Proxy Authentication Required: http://download.eclipse.org/releases/oxygen/compositeContent.xml
!STACK 1
!SUBENTRY 1 org.eclipse.ecf.identity 4 0 2019-07-17 18:37:50.301
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2019-07-17 18:37:50.331
!MESSAGE HTTP Proxy Authentication Required: http://www.pemicro.com/eclipse/updates/compositeContent.xml
!STACK 1
!SUBENTRY 1 org.eclipse.ecf.identity 4 0 2019-07-17 18:37:50.332
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2019-07-17 18:38:34.661
!MESSAGE Using manifest XSD 'manifest-schema/sdk_manifest_v3.3.xsd' for manifest 'C:\nxp\MCUXpressoIDE_10.3.1_2233\ide\plugins\com.nxp.mcuxpresso.core.datamodels.resources_10.3.0.201810041206\fragments\ksdk_manifest.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2019-07-17 18:38:34.676
!MESSAGE Using SDK manifest 'ksdk_manifest.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2019-07-17 18:38:35.128
!MESSAGE Using manifest XSD 'manifest-schema/sdk_manifest_v3.3.xsd' for manifest 'C:\nxp\MCUXpressoIDE_10.3.1_2233\ide\plugins\com.nxp.mcuxpresso.core.datamodels.resources_10.3.0.201810041206\override\override_manifest.xml'.
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2019-07-17 18:38:35.138
!MESSAGE Using SDK manifest 'override_manifest.xml'.
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.169
!MESSAGE System property http.proxyHost is set to 172.54.16.201 but should not be set.
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.189
!MESSAGE System property http.proxyPort is set to 8080 but should not be set.
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.199
!MESSAGE System property https.proxyHost is set to 172.54.16.201 but should not be set.
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.209
!MESSAGE System property https.proxyPort is set to 8080 but should not be set.
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:42:59.219
!MESSAGE Error connecting to http://mcuxpresso.nxp.com/SWTools/npidb/processors/2/5.0?processor=LPC824 with error code 407
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:42:59.239
!MESSAGE [NETWORK] getProcessor - server not available or other error
!STACK 0
com.nxp.swtools.kex.exceptions.MfactServerError: Server error. Code=407 for http://mcuxpresso.nxp.com/SWTools/npidb/processors/2/5.0?processor=LPC824
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpBinaryResponse(HttpHelper.java:138)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpBinaryResponse(HttpHelper.java:162)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpGetBinaryResponse(HttpHelper.java:176)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpGetXmlResponse(HttpHelper.java:75)
at com.nxp.swtools.kex.api.internal.MfactApiClient.getProcessor(MfactApiClient.java:356)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.listProcessor(KExProcessorsProvider.java:292)
at com.nxp.swtools.utils.processors.ProcessorDataUpdateUI.updateAndGetProcessorStatus(ProcessorDataUpdateUI.java:82)
at com.nxp.swtools.sdkproject.ImportToolchainProjectFactory.importToolchainProject(ImportToolchainProjectFactory.java:305)
at com.nxp.swtools.eclipse.handlers.OpenMexForProject.lambda$1(OpenMexForProject.java:134)
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.279
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.289
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.299
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.309
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:42:59.319
!MESSAGE Error connecting to http://mcuxpresso.nxp.com/SWTools/npidb/components/2/5.0 with error code 407
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:42:59.329
!MESSAGE [NETWORK] listComponents - server not available or other error
!STACK 0
com.nxp.swtools.kex.exceptions.MfactServerError: Server error. Code=407 for http://mcuxpresso.nxp.com/SWTools/npidb/components/2/5.0
at com.nxp.swtools.kex.api.internal.MfactApiClient.listComponents(MfactApiClient.java:541)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.listComponents(KExProcessorsProvider.java:383)
at com.nxp.swtools.utils.processors.ProcessorDataUpdateUI.downloadOrUpdateComponents(ProcessorDataUpdateUI.java:302)
at com.nxp.swtools.sdkproject.ImportToolchainProjectFactory.importToolchainProject(ImportToolchainProjectFactory.java:307)
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 18:42:59.339
!MESSAGE Processor 'LPC824' is not supported or data for processor not available (check internet connection)
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.693
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.698
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.702
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:42:59.707
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:42:59.711
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:42:59.716
!STACK 0
at com.nxp.swtools.provider.processors.KExProcessorsProvider.listProcessor(KExProcessorsProvider.java:281)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.getProcessorMasterToolInfo(KExProcessorsProvider.java:1234)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.downloadOrUpdateProcessor(KExProcessorsProvider.java:543)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.checkOrDownloadProcessor(KExProcessorsProvider.java:578)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.checkOrDownloadCommonConfig(KExProcessorsProvider.java:794)
at com.nxp.swtools.utils.importer.PreparedImportStatus.preparePrjImport(PreparedImportStatus.java:137)
at com.nxp.swtools.sdkproject.ImportToolchainProjectFactory.lambda$1(ImportToolchainProjectFactory.java:139)
at java.util.LinkedHashMap$LinkedValues.forEach(LinkedHashMap.java:608)
at com.nxp.swtools.sdkproject.ImportToolchainProjectFactory.importSourcesFromProject(ImportToolchainProjectFactory.java:135)
at com.nxp.swtools.sdkproject.ImportToolchainProjectFactory.importToolchainProject(ImportToolchainProjectFactory.java:322)
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 18:42:59.725
!MESSAGE board\clock_config.c contains YAML but processor is not supported [SDK/DATA]
!ENTRY com.nxp.swtools.core 4 0 2019-07-17 18:42:59.812
!MESSAGE [SDK]/Data] Invalid coreID: core0. Could not set it for BOARD_InitPins function
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:43:00.557
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:43:00.562
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:43:00.571
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:43:00.575
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:43:00.581
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:43:00.585
!STACK 0
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 18:43:00.602
!MESSAGE board\pin_mux.c contains YAML but processor is not supported [SDK/DATA]
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 18:43:00.607
!MESSAGE [SDK] The project does not contain any configuration/source file to import
!ENTRY com.nxp.swtools.eclipse.handlers 4 0 2019-07-17 18:43:00.650
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.408
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.418
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.428
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:48:34.428
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:48:34.438
!STACK 0
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.438
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.448
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.458
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:48:34.458
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:48:34.468
!STACK 0
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 18:48:34.468
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.499
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.513
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.517
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.522
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:48:34.528
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:48:34.533
!STACK 0
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 18:48:34.538
!ENTRY com.nxp.swtools.core 4 0 2019-07-17 18:48:34.565
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.822
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.826
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.831
!ENTRY org.eclipse.core.net 1 0 2019-07-17 18:48:34.835
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 18:48:34.840
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 18:48:34.845
!STACK 0
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 18:48:34.850
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 18:48:34.856
!ENTRY com.nxp.swtools.eclipse.handlers 4 0 2019-07-17 18:48:34.898
!ENTRY com.crt.log 1 0 2019-07-17 19:02:43.769
!MESSAGE Trying to connect to redlink server on port 3025.
!ENTRY com.crt.debugcommon 1 0 2019-07-17 19:02:43.780
!MESSAGE RedlinkServer telnet session connected on port 3025->61207 @ 127.0.0.1
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:02:57.000
!MESSAGE Telnet session connected on port 3330->61213 @ 127.0.0.1
!ENTRY org.eclipse.tm.terminal.connector.cdtserial 4 0 2019-07-17 19:03:31.132
!MESSAGE Error setting DCB (31)
!STACK 0
java.io.IOException: Error setting DCB (31)
at org.eclipse.cdt.serial.SerialPort.open0(Native Method)
at org.eclipse.cdt.serial.SerialPort.open(SerialPort.java:312)
at org.eclipse.tm.terminal.connector.cdtserial.connector.SerialConnector.connect(SerialConnector.java:76)
at org.eclipse.tm.internal.terminal.connector.TerminalConnector.connect(TerminalConnector.java:158)
at org.eclipse.tm.internal.terminal.emulator.VT100TerminalControl.connectTerminal(VT100TerminalControl.java:440)
at org.eclipse.tm.terminal.view.ui.tabs.TabFolderManager.createTabItem(TabFolderManager.java:325)
at org.eclipse.tm.terminal.view.ui.manager.ConsoleManager.openConsole(ConsoleManager.java:472)
at org.eclipse.tm.terminal.view.ui.manager.ConsoleManager.openConsole(ConsoleManager.java:412)
at org.eclipse.tm.terminal.view.ui.services.TerminalService$3.doRun(TerminalService.java:313)
at org.eclipse.tm.terminal.view.ui.services.TerminalService$3$1.run(TerminalService.java:286)
!ENTRY org.eclipse.tm.terminal.connector.cdtserial 4 0 2019-07-17 19:03:38.750
!MESSAGE Error opening \\.\COM7 (5)
!STACK 0
java.io.IOException: Error opening \\.\COM7 (5)
!ENTRY org.eclipse.tm.terminal.connector.cdtserial 4 0 2019-07-17 19:03:49.225
!STACK 0
!ENTRY org.eclipse.tm.terminal.connector.cdtserial 4 0 2019-07-17 19:03:58.903
!STACK 0
!ENTRY com.crt.log 1 0 2019-07-17 19:04:21.121
!ENTRY com.crt.log 1 0 2019-07-17 19:04:31.128
!MESSAGE Trying to connect to redlink server on port 3050.
!ENTRY com.crt.debugcommon 4 0 2019-07-17 19:04:31.228
!MESSAGE RedlinkServer Telnet session connection timeout expired.
!ENTRY com.crt.log 1 0 2019-07-17 19:04:41.138
!MESSAGE Trying to connect to redlink server on port 3075.
!ENTRY com.crt.debugcommon 4 0 2019-07-17 19:04:41.288
!ENTRY com.crt.debugcommon 4 0 2019-07-17 19:04:51.228
!ENTRY com.crt.log 1 0 2019-07-17 19:04:54.418
!ENTRY com.crt.debugcommon 1 0 2019-07-17 19:04:54.438
!MESSAGE RedlinkServer telnet session connected on port 3025->61253 @ 127.0.0.1
!ENTRY org.eclipse.cdt.dsf 4 10005 2019-07-17 19:04:55.283
!MESSAGE Request for monitor: '[Lorg.eclipse.cdt.dsf.debug.service.IRunControl$IContainerDMContext;@1fe8a00' resulted in a rejected execution exception.
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:04:55.283
!MESSAGE Exception logged
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@134e2e1 rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
at java.util.concurrent.ScheduledThreadPoolExecutor.execute(ScheduledThreadPoolExecutor.java:622)
at org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor.execute(DefaultDsfExecutor.java:462)
at org.eclipse.cdt.dsf.gdb.internal.ui.actions.DsfTerminateCommand.canExecute(DsfTerminateCommand.java:94)
at com.crt.dsfdebug.dsf.override.commands.CRTDsfTerminateCommand.canExecute(CRTDsfTerminateCommand.java:85)
!ENTRY org.eclipse.debug.ui 4 2 2019-07-17 19:04:55.293
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.debug.ui".
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@1acfc7c rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
at org.eclipse.cdt.dsf.debug.ui.actions.DsfResumeCommand.canExecuteSingle(DsfResumeCommand.java:79)
at org.eclipse.cdt.dsf.debug.ui.actions.DsfResumeCommand.canExecute(DsfResumeCommand.java:49)
!ENTRY org.eclipse.debug.ui 4 120 2019-07-17 19:04:55.293
!STACK 0
!ENTRY org.eclipse.cdt.dsf 4 10005 2019-07-17 19:04:55.303
!MESSAGE Request for monitor: '[Lorg.eclipse.cdt.dsf.debug.service.IRunControl$IContainerDMContext;@12f0fa6' resulted in a rejected execution exception.
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:04:55.313
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@8960cb rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 2 2019-07-17 19:04:55.313
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@ea5707 rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 120 2019-07-17 19:04:55.323
!STACK 0
!ENTRY org.eclipse.cdt.dsf 4 10005 2019-07-17 19:04:55.323
!MESSAGE Request for monitor: '[Lorg.eclipse.cdt.dsf.debug.service.IRunControl$IContainerDMContext;@1902ccf' resulted in a rejected execution exception.
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:04:55.333
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@c5b04b rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 2 2019-07-17 19:04:55.333
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@1b7e9c3 rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 120 2019-07-17 19:04:55.343
!STACK 0
!ENTRY org.eclipse.cdt.dsf 4 10005 2019-07-17 19:04:55.353
!MESSAGE Request for monitor: '[Lorg.eclipse.cdt.dsf.debug.service.IRunControl$IContainerDMContext;@508b3d' resulted in a rejected execution exception.
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:04:55.353
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@151f6f3 rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 2 2019-07-17 19:04:55.363
!STACK 0
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask@6f91cc rejected from org.eclipse.cdt.dsf.concurrent.DefaultDsfExecutor@686df0[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 3508]
!ENTRY org.eclipse.debug.ui 4 120 2019-07-17 19:04:55.363
!STACK 0
!ENTRY com.crt.dsfdebug 1 0 2019-07-17 19:04:59.298
!MESSAGE Telnet session connected on port 3330->61258 @ 127.0.0.1
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.329
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.339
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.346
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.352
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 19:05:21.359
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 19:05:21.366
!STACK 0
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.378
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.388
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.394
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.400
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 19:05:21.407
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 19:05:21.414
!STACK 0
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 19:05:21.421
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.455
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.464
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.473
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:21.479
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 19:05:21.485
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 19:05:21.492
!STACK 0
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 19:05:21.500
!ENTRY com.nxp.swtools.core 4 0 2019-07-17 19:05:21.544
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:22.058
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:22.067
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:22.073
!ENTRY org.eclipse.core.net 1 0 2019-07-17 19:05:22.080
!ENTRY com.nxp.swtools.kex.api.internal.HttpHelper 4 0 2019-07-17 19:05:22.086
!ENTRY com.nxp.swtools.kex.api.internal.MfactApiClient 4 0 2019-07-17 19:05:22.092
!STACK 0
!ENTRY com.nxp.swtools.utils.importer 4 0 2019-07-17 19:05:22.099
!ENTRY com.nxp.swtools.sdkproject 4 0 2019-07-17 19:05:22.107
!ENTRY com.nxp.swtools.eclipse.handlers 4 0 2019-07-17 19:05:22.223
you are behind proxy. You can do:
a) try to access web page to make sure your computer is logged to the proxy, it might help other applications
b) ask your IT to white list the mcuxpresso.nxp.com
c) upgrade to Config Tools v6 for which you can download the data using browser at mcuxpresso.nxp.com and then import in the tool (using FIle | Import ...)
d) MCUXpresso Config Tools detects proxy settings as defined in the operating system. In case of error, you can
specify proxy information in the tools.ini file, located in the <install_dir>/bin/ folder. Make sure the file contains the
following lines:
◦ Djava.net.useSystemProxies=true (already present by default)
◦ Dhttp.proxyHost=<somecompany.proxy.net>
◦ Dhttp.proxyPort=80
please make sure the proxy does not require authentication.
Libor
sorry please give clear expalnation
