Where can I find the example of bootloader for imxrt 1050
andydong1
Hi all,
As title, can someone provide the example for me ?
I store image in dataflash and I want to use bootloader to update my application from SD card.
thanks
Andy Dong
kerryzhou
Hi Andy Dong,
    So, you need to read the flashloader source code carefully, you can boot from the app, then check the app version, then decide update the app or not.,about the SD card  and nor flash driver, the flashloader already contains it, you can check the code carefully. You need to modify it by yourself.
led_demo_evk code in folder:
SDK_2.6.1_EVKB-IMXRT1050\boards\evkbimxrt1050\bootloader_examples\demo_apps
is just the app code.
The flashloader code is:
\SDK_2.6.1_EVKB-IMXRT1050\boards\evkbimxrt1050\bootloader_examples\flashloader
So, if you want to write your own flashloader code, you need to refer the flashloader project, not the led, led is just the app code.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
kerryzhou
Hi Andy Dong,
Please refer to the NXP official flashloader:
Flashloader i.MX-RT1050
The source code can be downloaded from the SDK, please go to this link:
Welcome | MCUXpresso SDK Builder
Choose the EVKB-RT1050 board, in the middleware, please select  mcu-boot:
The flashloader already contains the SD card boot, please refer to it.
Kerry
andydong1
Hi, Kerry Zhou
Thanks for your quick reply
I have downloaded the source code
Can you tell me how to use flashloader to update my application from SD card for detail ?
Thanks!
Andy Dong
kerryzhou
Hi Andy Dong,
    If you also download the flashloader:
https://www.nxp.com/webapp/Download?colCode=IMX-RT1050-FLASHLOADER&appType=license
There has some document about it.
  But, about the detail usage, if you are using the official MIMXRT1050-EVKB board, please download the MCUBootUtility tool from this link:
https://github.com/JayHeng/NXP-MCUBootUtility/releases/tag/v1.4.0
The software user manual link is:
GitHub - JayHeng/NXP-MCUBootUtility: A one-stop boot utility tool based on Python2.7+wxPython4.0, it...
Wish it helps you!
Kerry
andydong1
Hi, Kerry Zhou
I know the MCUBootUtility
But I think I didn't express my demand clearly.
I will put the latest application (image) in SD card
Everytime when I power on the board, the flashloader ( bootloader?) will check the version of application
If it's not the latest one , then flashloader will update the application from SD card to dataflash(maybe Nor flash or SDRAM).
Just like the firmware upgrade. Can you tell me how to implement it ?
Also, In MIMXRT1052xxxxB -> bootloader_examples
led_demo_evk_ram, led_demo_evk_flexspi_nor, flashloader,
These three examples don't have any readme.txt
I don't know what these three example exactly do. Can you explain to me ?
Thanks!!
Andy Dong
kerryzhou
Hi Andy Dong,
Wish it helps you!
Kerry
andydong1
Hi, Kerry Zhou
One more thing I want to check.
In Flashloader_RT1050_1.1\Tools\mfgtools-rel\Profiles\MXRT105X\OS Firmware\ ivt_flashloader.bin
this .bin is generated from this Project ( \boards\evkbimxrt1050\bootloader_examples\flashloader ) ,right?
Andy Dong
kerryzhou
Hi Andy Dong,
  Yes you are right.
Wish it helps you!
Kerry
