the question for reference Manual about ECC
814420552
why the two pictures's description is different?
for this pictrue whether it means S32k11x is not allowed to disable ECC function and ECC is enabled by default?  and I also hope to know  ‘CF0’ is belong MCM_LMDR0 or MCM_LMDR1?  wish your help , thank you !!
anther question  as flowing
according to the above two picture, I check the data for offset 400 - 408, But this result is different with The following picture Table 10-1, Please help me  or tell me where my understanding is wrong?
danielmartynek
These are the S32K148 reset values, it is just en example:
LMDR0: SRAM_L
LMDR1: SRAM_U
Therefore, LMDR0[CF0] is reserved.
From S32K1xx_Memory_Map.xlsx:
