Iam using MCUMX software with KW41Z SDK for DTLS examples.
Could you please let me know which library has been used to implement DTLS session, Is it mbedtls?
If so kindly specify the file path for the same.
Thanks in advance,
Praneeth
It will depend on the example you use, if you use the benchmark or the selftest it will use the mbedtls, if you use the thread examples, there are some defines that you can set where you will be able to configure your examples and most of the elements and functions are in a library.
Estephania
