Does DEVKIT MCP5748G feature HSM?
fab_
I'm wondering if the DEVKIT-MCP5748G is featured with HSM. If I'm correct, the datasheet says only MCP5748GS is equiped with a HSM.
In case it isn't equiped with HSM, is there an alternative module or feature for data encryption on the MCU?
Thanks for your help.
Cheers, Fab_
ankur_kala
No Devkit is HSM enabled. In case you want to work with HSM enabled parts, you need to get in touch with your local sales representative. HSM enabled parts come with security firmware programmed.
Ankur
fab_
Hi Ankur, thanks for the quick response. Too bad the DEVKIT doesn't have the feature.
Also, thanks to petervlna‌ for you effort.
Kind regards,
Fabian
petervlna
Not only S version has HSM. Also T and H versions:
I have check the DEVKIT here in lab and it is equiped with S version. So there is HSM available on DEVKIT.
However I cannot see any additional information about HSM availability on our web page.
regards,
Peter
