The waveforms of the SCL and SDA pins of the lpi2c_mater_S32K148 official routine are sharp waves.The pins I measured with an oscilloscope.The waveform is shown in the picture.why?
HI,
Thank you for your answer, but now I have a headache. My S32K148EVB board can't download the program through OpenSDA. Maybe it's because my chip was locked because I chose to jump the cap with hot-plug power. Is there any way to solve this problem?I plugged in the power supply and the USB connection between the computer and the MCU. The firmware I chose was also correct. The picture is an error that occurred after I downloaded the program.
Jianyang
Thank you for your reply, but my hardware connections are good. Excuse me, what else do you mean by hardware?
This is not the phenomenon that chip was locked. Please check your hardware.
HI,
Because the pins work in Open-Drain Mode. The signals are not driven HIGH by the IO drivers but they are pulled up by pull-up resistors on the bus. The signals depend on the pull-up resistance and the capacitance of the bus.
