Problem to uninstall the MCUExpresso IDE
stanley1
Could you help me for my case of having problem to uninstall the MCUExpresso IDE version 11.0.0_2516?
The .bak_0 text file indicates that 'The profile is currently in use'. The end result is that the '.metadata' is not able to be removed.
Thanks in advance for helping me.
SL
danielchen
Hi Stanley:
Sometimes I have the same problem, it is because I am trying to uninstall the IDE while it is still in running state.  I exit the IDE or restart my PC can fix this issue.
stanley1
Thanks Daniel!
