S12ZVCA19 array size
aaronlee
Contributor V
Our project use S12ZVCA19. We need create an array to save 30000 strings (each string =10 characters).
Is it can work? How to make sure the free space in memory?
Aaron
Tags (2)
aaronlee
Contributor V
Hi Daniel,
We use SD card to store. Thanks for your information. It's very useful.
BR, Aaron
aaronlee
Contributor V
Hi, Daniel,
uint32_t      array[30000];
Can I use that define in S12ZVCA19?
BTW, I have define a lot of variable, how to check the free space of variable?
Best Regard,
Aaron
danielmartynek
Hi Aaron,
The S12ZVCA19 MCU has 12KB of SRAM.
You can't use a 120KB variable.
Please check the linker file and the map file.
BR, Daniel
aaronlee
Contributor V
Hi Daniel,
BR, Aaron
danielmartynek
Hi Aaron,
I'm afraid you can't store 300KB on a 192KB Flash.
BR, Daniel
