It looks like that LSDK on your host PC is not completely installed.
Use the following command sequence under Ubuntu 18:
$ sudo apt-get install git
$ tar xvzf flexbuild_lsdk1809.tgz
$ cd flexbuild
$ source setup.env
wget http://www.nxp.com/lgfiles/sdk/lsdk1809/app_components_arm64.tgz
wget http://www.nxp.com/lgfiles/sdk/lsdk1809/bootpartition_arm64_lts_4.14.tgz
wget http://www.nxp.com/lgfiles/sdk/lsdk1809/arm64-modules-4.14.67.tgz
wget http://www.nxp.com/lgfiles/sdk/lsdk1809/bootpartition_arm64_lts_4.9.tgz
wget http://www.nxp.com/lgfiles/sdk/lsdk1809/arm64-modules-4.9.124.tgz
flex-builder -i mkrfs -a arm64
tar xvzf app_components_arm64.tgz -C build/apps
sudo tar xvzf arm64-modules-4.14.67.tgz -C build/rfs/rootfs_ubuntu_bionic_arm64/lib/modules
flex-builder -i compressrfs -a arm64
sudo tar xvzf arm64-modules-4.9.124.tgz -C build/rfs/rootfs_ubuntu_bionic_arm64/lib/modules
flex-builder -c linux -a arm64
flex-builder -i merge-component -a arm64
flex-builder -c uboot -m ls1043ardb -b sd
Pavel Chubakov
