Hi guys,
I have been looking at some SDK simple examples that use the debug console. The examples need the use of a serial terminal installed in the PC to see the debug console output.
My problem is that I haven't been able to figure out where in the code the LPUART is routed via the USB interface. The serial_manager is configured to be used as UART and not as a CDC device. This makes me think that the LPUART by default is attached to the USB peripheral.
If someone can shed some light on this I will be deeply grateful.
Thank you
Patricio
Solved! Go to Solution.
Use section 2.11 [OpenSDA circuit (DAP-Link)] of "MIMXRT1060 Evaluation Kit Board Hardware User's Guide"
https://www.nxp.com/webapp/Download?colCode=UM11151
and "Freelink Interface" sheet of the EVK schematic
https://www.nxp.com/webapp/Download?colCode=MIMXRT1060-EVK-DESIGN-FILE-A2
i.MX RT1060 Evaluation Kit | NXP
For more details:
OpenSDA Serial and Debug Adapter | NXP
Yuri
For more details:
Yuri
Thank you Yuri!
Have a great day you too!
