Using BL instruction to jump to an absolute address in C file
tyut-zhangjie
Hi Support Team:
I am using the codewarrior for one boot project using the Pictus MCU.
Now I met an problem about using BL instruction.
I want to jump to the application software when I check the condition is OK, so I write it in one C file:
#define _APPL_ENTRY    0x2004
if (Main_u16ApplMakrker != 0xFFFF)
      asm (" bl _APPL_ENTRY");
else
    /* stay at boot  */
but there is the fault that "illegal operand" about bl.
How I should do it?
Thanks very much!
Tags (2)
lukaszadrapa
in C code, you can use something like:
typedef void (*func_ptr)();
(*(func_ptr)ADDRESS)();
Lukas
tyut-zhangjie
Thanks very much.
In fact, I had done it what you said.
But I can not understand why the BL instruction can not work. is it must a "Lable" followed by BL instruction?
Anyway, the problem is fixed.
Thanks again for your reply.
