Problem with System Core Clock
athmesh_n
 I am using LPC1754FBD80 controller, as per datasheet max clock rate is 100MHz. But after the running the code, SystemCoreClock is showing 120MHz as value.
Where is the issue?
Labels (4)
nxf54947
Hi athmesh.n
Could you attach a screenshot of  where you found  that SystemCoreClock is equal to 120 MHz?
Ruben
