How can I work usbip (usb over ip) on LS1046ardb ?
Please boot up LS1046 system with LSDK Unbuntu rootfs.
Please refer to the procedure for USB over IP on Unbuntu.
USB over IP On Ubuntu · solarkennedy/wiki.xkyle.com Wiki · GitHub.
If you mean USB Gadget mode, please refer to "USB 3.0 Host/Peripheral Linux Driver User Manual" to configure the target as USB Gadget.
Hello Yiping Wang,
Thank you answering my question.
I had followed the steps on the website,
I did the steps:
$ sudo apt-get update
$ sudo apt-get install linux-tools-generic
$ modprobe usbip_test
then, return:
modprobe: FATAL: Module usbip_host not found in directory /lib/modules/4.14.122
I install kernel :
19.06 - 4.14.12
flex-installer -i auto -m ls1046ardb -d /dev/sdx
Please refer to Trouble with usbip · Issue #3449 · dnschneid/crouton · GitHub .
Please refer to install usbip on Ubuntu 14.04.2 - Ask Ubuntu .
