Leaptronix programming spec
ryantseng
This is Alex from Leaptronix.
We are the third party of programmer.
Could we apply below IC programming spec
1.MC908QY4ACDWE
2.LPC1112FHN33/101.5
3.DSP56F807PY80E
My email is: overseas@leap.com.tw
Thank you and have a good day.
FelipeGarcia
Hi Alex,
The requested documents are below:
1.MC908QY4ACDWE
This MCU is not recommended for new designs so the information available is limited. We recommend you to migrate to a more recent MCU. However, please take a look to the below documents that you may find helpful.
Reference Manual and Datasheet:
https://www.nxp.com/docs/en/reference-manual/CPU08RM.pdf
https://www.nxp.com/docs/en/data-sheet/MC68HC908QY4.pdf
Flash Programing and On-Chip Flash Programming:
https://www.nxp.com/docs/en/application-note/AN2635.pdf
https://www.nxp.com/docs/en/application-note/AN2156.pdf
Other useful links:
https://www.nxp.com/docs/en/application-note/AN1744.pdf    You need this to enter MON08 mode (programming mode).
https://www.nxp.com/docs/en/application-note/AN2317.pdf
https://www.nxp.com/docs/en/application-note/AN2305.pdf
https://www.nxp.com/docs/en/user-guide/UM10398.pdf (Chapter 26)
3.DSP56F807PY80E
https://www.nxp.com/docs/en/application-note/AN1926.pdf
Hope it helps!
Felipe
FelipeGarcia
Hi Alex,
1.MC908QY4ACDWE
Other useful links:
3.DSP56F807PY80E
Hope it helps!
Felipe
