there is a question about s32r274 flash wirte and read.
Now I can wirte and read in debug mode,but when i change it to release mode, I can't wirte data to flash.
There is my code, it can work in debug mode .but it can't work in release mode,can you help me find where is wrong?
Hello Lukas,
I am facing the same issue with s32r274 flash write, as Piao Bht asked.
I mean to say "I can erase in debug mode(I am debugging step by step), but when i change it to release mode (free run GO in debugger), I can't erase data to flash and getting exception MachineCheck.
Please help it is urgent ..
Thanks!
which IDE and which version do you use?
I did quick test in S32 Design Studio v2017.R1 with latest update 11 installed and it works in both debug and release mode. I just copied your code to new empty project with no other changes.
Lukas
