AIOP in LS2088A
AIOP in LS2088A
pradeep_t
HI Team,
How to test memory of AIOP (DP_DDR) in uboot and kernel, we are using LS2088ARDB board.
ufedor
In the QorIQ LS2088A Reference Manual it is stated that only AIOP can access the DP DDR.
The only way to perform the DP DDR test is to use the DDR test registers - refer to the QorIQ LS2088A Reference Manual, 12.5.59 DDR Memory Test Control Register (DDR_MTCR).
