the antenna is provided in various NFC development kits f.ex. OM26630FDK.
What are the L, R, C equivalent values of the 30x50mm antenna ?
What are the values of the fitted components in the matching circuit ?
You will need to perform an antenna design process in order to get the values you are asking for.
Please check this guide for more information about this.
Estephania
