S32R274 Data cache Flush?
amulrass_vazhum
I am using S32R274 controller, I need to Flush the Data-cache to Main memory on certain conditions.
The S32R274 controller supports write-through mode only, so invalidating a cache-line by L1FINV0 is sufficient? or do I need to use dcbf instruction?
Amulrass V
amulrass_vazhum
Hi, thanks a lot:)
davidtosenovjan
Hi, there is no need of flush cache content as cache line is allocated only during reads and writes always accesses also target memory. As copy-back mode is not present on the device, invalidate operation is enough.
