DebugConsole adds 'swo' but files are missing
ingenutec
The v2.5 SDK adds SERIAL_PORT_TYPE_SWO as an output option, but if this is defined, then serial_manager.h attempts to include serial_port_swo.h which does not exist in the SDK.
This is also not in the current documentation.  Is this a work in progress?
Are there any plans to add SEGGER_RTT as an output option in the DebugConsole?
Robert Palmer
kerryzhou
Hi robert palmer,
  Please check the attached swo files.
  You can unzip it, then put the files in folder: SDK_2.6.0_FRDM-K82F\components\serial_manager
  You can try it on your side.
Kerry
kerryzhou
Hi robert palmer ,
  Please tell me which detail SDK you are using? Tell me the kinetis chip part number.
  I will check it, and report it to our SDK department.
Kerry
ingenutec
I'm looking at the MK8x family SDK for Mac, Linux and Windows.
kerryzhou
Hi robert palmer,
  I have reproduce the problem which you mentioned, I will help you to report it to our SDK department.
Kerry
