FXTH87 interrupt
FXTH87 interrupt
binchengtao
FXTH87,@0x8F address,How do you define each bit of this interrupt?
TomasVaverka
Hi Bincheng,
At address 0x8F is located the TPMS_INTERRUPT_FLAG, which is a variable updated in the interrupt vectors, holding information on which interrupts occurred. The bits are described in the Firmware User Guide, below is an extract of the relevant section:
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
