About the problem of sector erasing in 【driver_examples\flexspi\nor\polling_transfer】 routines
fancyop
There is no write enablement in the flexspi_nor_flash_erase_sector program,The original program is:
It should be written as the following program, the section in the red box needs to be addedotherwise the erase sector will not succeed.
jeremyzhou
Hi  Op Fancy
for the opportunity to serve you.
Thanks for your reply, I'd like to do a test by myself to replicate the phenomenon you mentioned, so whether you can tell me which RT chip you talk about.
TIC
fancyop
i.MX RT1050
