QT can't find mediaplayer service in iMX8MQ
bailin
Hi, Guys:
Currently I'm porting QT App from Ubuntu into imx8mq.
MACHINE=imx8mqevk DISTRO=fsl-imx-xwayland  source fsl-setup-release.sh -b build-xwayland
bitbake fsl-image-qt5-validation-imx
bitbake meta-toolchain-qt5
Linux version:4.14.98
QT version:5.10.1
My problem is related media player and OpenGL.
When I run QT application, it says:
 defaultServiceProvider::requestService(): no service found for - "org.qt-project.qt.mediaplayer"
But gstream can play video normally.
So can we let QT use gstream plugin to play video?
Another question is that there is no OpenGL available for xwayland, all 2D/3D apps in example directory are failed.
Thanks very much.
Tags (4)
joanxie
for this message, it seems you need add "PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer alsa" in the local. conf, for openGL, pls refer to the linux reference manual, focus on the chapter 5.1 Graphics Processing Unit (GPU)
