Hello!
I use Zigbee Stack in my project. I have a problem with zigbee size. I tried to use different files "lib_zps_zcp_cm0.a", "lib_zps_ed_cm0.a" and "lib_zps_cm0.a". And when I used "lib_zps_ed_cm0.a", I got a flash reduction. I tried to find a description of these files, but I did not find it anywhere. What is the difference between "lib_zps_zcp_cm0.a", "lib_zps_ed_cm0.a" and "lib_zps_cm0.a"?
Hi Yaroslav,
The lib differences depend on the device that you are working on. As you know, the coordinator requrires more commands than the end device. That is the reason that you have a flash reduction on the LIb_zps_ed_cm0.a.
Mario
