problem arise on console
aravindpb5009
hai
 I  am using lpc824  mcuxpresso   when i try to start my code console doesn't display any thing shows some problem   but serial terminal i got the o/p . console appear some error  please find my attachment  let me know the solution
*** assert failed : ../drivers/fsl_usart.c:363 : diff < ((baudrate_Bps / 100) * 3)
thanks & regards
Aravind P
ZhangJennie
Hi Aravind palanisamy
Thank you for contacting us.
Is your project from our SDK or your developed by yourself?
if NXP demo code, where is link?
Anyway, please let me know how to reproduce it thus I can check it further.
Jun Zhang
aravindpb5009
HAI
plz let me know how many ports are available out of 29 pins in LPC824 CONTROLLER
ZhangJennie
I guess you use LPC824 HVQFN33 package package.
this chip totally has 32pins. Vdd, Vrefp, Vrefn can't be used as GPIO.
Other 29 pins: in debug phase, SWDCLK and SWDIO are used as debug interface. if you need reset feature, PIO0_5/RESET is used as reset. others can all work for GPIO.
Jun Zhang
aravindpb5009
hai
yes i  am using  LPC824 HVQFN33  package i have one doubt in this package there is no ports?
but in sdk example codings they mentioned port 1 ,port 2  but in the user manual there is no ports available. plz let me know the clear explanation in this package there is having any ports or not
thank you
ZhangJennie
Aravind palanisamy
LPC824 HVQFN33 only has one port. it's port0. there are 29 pins distributing to port0, PIO0_0 ~ PIO0_28.
Jun Zhang
aravindpb5009
thanks you
plz let me know what is Hysteresis
ZhangJennie
welcome.
Jun Zhang
aravindpb5009
ZhangJennie
GPIO feature hysteresis is to prevent spurious state changes.
Virtually all GPIO inputs use a principle called hysteresis to prevent spurious changes in state when an input value changes. “Hysteresis is the dependence of a system on not only its current environment but also on its past” (read more).
BTW, if you have new question. please open a new thread. Thanks.
aravindpb5009
which debugger is better for LPC824 IN MCUXPRESSO ide  currently i am using only link server debugger only its sufficient or not plz let me know which debugger is better to buy for our mcuxpresso ide
ZhangJennie
This is a new issue about MCUXpresso IDE, please create a new thread to https://community.nxp.com/community/mcuxpresso/mcuxpresso-ide
Thanks.
