CAN on i.MX RT1064 EVK
klinsmann_mah5
According to the MIMXRT1064 EVK Board Hardware User's Guide Figure 1, it is said that the EVK contained 1 CAN module. However, Figure 2 does not show any CAN module.
As I have purchased the EVK, does the EVK have any CAN module?
Thanks!
jorge_a_vazquez
Hi KLINSMANN MAH
The RT1064 device has 3 flexCAN modules and one of them support CANFD, but in the evaluation board we only enable (it has the pins available) one of them, because it is connected to the PHY, as Markus mentioned, you can check the schematic and you will find the J11 with this pins.
Jorge Alcala
Masmiseim
Senior Contributor I
take a look at page eight of the Schematics of your Board. There you will find the CAN-Part
Best Regards
