How to use AutoRelock Attributes of Door Lock cluster in ZB ProStack HA on JN-5169
fedyabogapov
Hello!
I am working with a door lock cluster on JN-5169 Zigbee Pro Stack HA. Is it possible to use AuroRelock Attribute functionality? Do you have support of this in SDK? Thanks in advance.
Best regards, Fedir
Embedded Developer
OMO Systems
Labels (2)
mario_castaneda
Hi Fedir,
Unfortunately, this attribute is not implemented in this SDK.
I am not sure if this attribute could help you.
CLD_DOOR_LOCK_ATTR_NUMBER_OF_MINUTES_DOOR_OPENED
https://www.nxp.com/docs/en/user-guide/JN-UG-3103.pdf
Mario
