No IVOR1 exception even after ERM module reports errors
ignatiusmichael
Hi ,
I am trying to inject an error via EIM and detect via ERM as per example. the example is working as  expected but when in do the same thing in my code my ERM is detecting the error but is not able to invoke IVOR1 handler.
link to example https://community.nxp.com/docs/DOC-328097
when i execute it my ERM reports that the error is injected but the function Machine_check_handler() is not being invoked by IVOR1 WHY?
I am using the same assembly files given in the above example for startup and interrupt initialization
Debugger O/P
BEFORE
/** Cause an error by read operation */
test_read = test[0];
Core Registers
R0 0083DB98 R8 1 R16 0 R24 4004185A ^S+ ^Stack_+
R1 40080F30 R9 8A R17 0 R25 00857138
R2 0085F0B4 R10 0 R18 0 R26 0085712C
R3 02009000 R11 00856FF0 R19 0 R27 00857138
R4 1000 R12 1 R20 0 R28 40080FB0
R5 FFE6422C R13 40048000 R21 0 R29 40080F5C
R6 FFF64000 R14 0 R22 0 R30 40080F64
R7 1 R15 0 R23 0 R31 1
TBL EFB993C2 XER 0 CR 20000000 LR 0083DB98
TBU F0D20C0C USPRG03F8F507F CTR 4004189E IP 0083DF38
SPRG0 BD8EFB97 SRR0 00853360 IVPR 00850000 MSR 02008000
SPRG1 590CEEFB SRR1 1000 DEAR 158E0418 PVR 816A0000
SPRG2 641FABE7 CSRR0 6E9B5AB6 ESR 0 DEC 0BABEAFE
SPRG3 E3EB176A CSRR1 C43E7793 MCSR 0 DECAR DC6A1668
SPRG4 B14F767B MCSRR075FE2A71 MCAR 000CF001 TCR 0
SPRG5 CB65DC71 MCSRR1740EFDBF TSR 0
SPRG6 E94FF9FD PID 0
SPRG7 F8A9D1F6
SPRG8 8DCEC43D UCLE _ SPE S WE _ CE _ EE E PR _
SPRG9 EFD7A7BF FP _ ME _ DE _ IS _ DS _ RI _
EIM - Error Injection Module
EIMCR 00000001 GEIEN 01: Enabled
EICHEN 40000000 EICH0EN 00: Error injection is disabled on Error Injection Channel 0
EICH1EN 01: Error injection is enabled on Error Injection Channel 1
EICH2EN 00: Error injection is disabled on Error Injection Channel 2
EICH3EN 00: Error injection is disabled on Error Injection Channel 3
EICH4EN 00: Error injection is disabled on Error Injection Channel 4
EICH5EN 00: Error injection is disabled on Error Injection Channel 5
EICHD0_WORD0 00000000 CHKBIT_MASK 00
EICHD0_WORD1 00000000 B0_3DATA_MASK 00000000
EICHD0_WORD2 00000000 B4_7DATA_MASK 00000000
EICHD1_WORD0 00000000 CHKBIT_MASK 00
EICHD1_WORD1 00000001 B0_3DATA_MASK 00000001
EICHD1_WORD2 00000000 B4_7DATA_MASK 00000000
EICHD2_WORD0 00000000 CHKBIT_MASK 00
EICHD2_WORD1 00000000 B0_3DATA_MASK 00000000
EICHD2_WORD2 ???????? B4_7DATA_MASK
EICHD3_WORD0 00000000 CHKBIT_MASK 00
EICHD3_WORD1 00000000 B0_3DATA_MASK 00000000
EICHD3_WORD2 00000000 B4_7DATA_MASK 00000000
EICHD4_WORD0 00000000 CHKBIT_MASK 00
EICHD4_WORD1 00000000 B0_3DATA_MASK 00000000
EICHD4_WORD2 00000000 B4_7DATA_MASK 00000000
EICHD5_WORD0 00000000 CHKBIT_MASK 00
EICHD5_WORD1 00000000 B0_3DATA_MASK 00000000
EICHD5_WORD2 00000000 B4_7DATA_MASK 00000000
eMIOS - Configurable Enhanced Modular IO Subsystems
EQADC - Enhanced Queued Analog-to-Digital Converters
ERM - Error Reporting Module
CR0 00000000 ESCIE0 00: Interrupt notification of Memory 0 single-bit correction events is disabled
ENCIE0 00: Interrupt notification of Memory 0 non-correctable error events is disabled
ESCIE1 00: Interrupt notification of Memory 1 single-bit correction events is disabled
ENCIE1 00: Interrupt notification of Memory 1 non-correctable error events is disabled
ESCIE2 00: Interrupt notification of Memory 2 single-bit correction events is disabled
ENCIE2 00: Interrupt notification of Memory 2 non-correctable error events is disabled
ESCIE3 00: Interrupt notification of Memory 3 single-bit correction events is disabled
ENCIE3 00: Interrupt notification of Memory 3 non-correctable error events is disabled
ESCIE4 00: Interrupt notification of Memory 4 single-bit correction events is disabled
ENCIE4 00: Interrupt notification of Memory 4 non-correctable error events is disabled
ESCIE5 00: Interrupt notification of Memory 5 single-bit correction events is disabled
ENCIE5 00: Interrupt notification of Memory 5 non-correctable error events is disabled
ESCIE6 00: Interrupt notification of Memory 6 single-bit correction events is disabled
ENCIE6 00: Interrupt notification of Memory 6 non-correctable error events is disabled
ESCIE7 00: Interrupt notification of Memory 7 single-bit correction events is disabled
ENCIE7 00: Interrupt notification of Memory 7 non-correctable error events is disabled
CR1 00000000 ESCIE8 00: Interrupt notification of Memory 8 single-bit correction events is disabled
ENCIE8 00: Interrupt notification of Memory 8 non-correctable error events is disabled
ESCIE9 00: Interrupt notification of Memory 9 single-bit correction events is disabled
ENCIE9 00: Interrupt notification of Memory 9 non-correctable error events is disabled
ESCIE10 00: Interrupt notification of Memory 10 single-bit correction events is disabled
ENCIE10 00: Interrupt notification of Memory 10 non-correctable error events is disabled
ESCIE11 00: Interrupt notification of Memory 11 single-bit correction events is disabled
ENCIE11 00: Interrupt notification of Memory 11 non-correctable error events is disabled
ESCIE12 00: Interrupt notification of Memory 12 single-bit correction events is disabled
ENCIE12 00: Interrupt notification of Memory 12 non-correctable error events is disabled
ESCIE13 00: Interrupt notification of Memory 13 single-bit correction events is disabled
ENCIE13 00: Interrupt notification of Memory 13 non-correctable error events is disabled
ESCIE14 00: Interrupt notification of Memory 14 single-bit correction events is disabled
ENCIE14 00: Interrupt notification of Memory 14 non-correctable error events is disabled
ESCIE15 00: Interrupt notification of Memory 15 single-bit correction events is disabled
ENCIE15 00: Interrupt notification of Memory 15 non-correctable error events is disabled
CR2 00000000 ESCIE16 00: Interrupt notification of Memory 16 single-bit correction events is disabled
ENCIE16 00: Interrupt notification of Memory 16 non-correctable error events is disabled
ESCIE17 00: Interrupt notification of Memory 17 single-bit correction events is disabled
ENCIE17 00: Interrupt notification of Memory 17 non-correctable error events is disabled
ESCIE18 00: Interrupt notification of Memory 18 single-bit correction events is disabled
ENCIE18 00: Interrupt notification of Memory 18 non-correctable error events is disabled
ESCIE19 00: Interrupt notification of Memory 19 single-bit correction events is disabled
ENCIE19 00: Interrupt notification of Memory 19 non-correctable error events is disabled
SR0 00000000 SBC0 00: No single-bit correction event on Memory 0 detected
NCE0 00: No non-correctable error event on Memory 0 detected
SBC1 00: No single-bit correction event on Memory 1 detected
NCE1 00: No non-correctable error event on Memory 1 detected
SBC2 00: No single-bit correction event on Memory 2 detected
NCE2 00: No non-correctable error event on Memory 2 detected
SBC3 00: No single-bit correction event on Memory 3 detected
NCE3 00: No non-correctable error event on Memory 3 detected
SBC4 00: No single-bit correction event on Memory 4 detected
NCE4 00: No non-correctable error event on Memory 4 detected
SBC5 00: No single-bit correction event on Memory 5 detected
NCE5 00: No non-correctable error event on Memory 5 detected
SBC6 00: No single-bit correction event on Memory 6 detected
NCE6 00: No non-correctable error event on Memory 6 detected
SBC7 00: No single-bit correction event on Memory 7 detected
NCE7 00: No non-correctable error event on Memory 7 detected
SR1 00000000 SBC8 00: No single-bit correction event on Memory 8 detected
NCE8 00: No non-correctable error event on Memory 8 detected
SBC9 00: No single-bit correction event on Memory 9 detected
NCE9 00: No non-correctable error event on Memory 9 detected
SBC10 00: No single-bit correction event on Memory 10 detected
NCE10 00: No non-correctable error event on Memory 10 detected
SBC11 00: No single-bit correction event on Memory 11 detected
NCE11 00: No non-correctable error event on Memory 11 detected
SBC12 00: No single-bit correction event on Memory 12 detected
NCE12 00: No non-correctable error event on Memory 12 detected
SBC13 00: No single-bit correction event on Memory 13 detected
NCE13 00: No non-correctable error event on Memory 13 detected
SBC14 00: No single-bit correction event on Memory 14 detected
NCE14 00: No non-correctable error event on Memory 14 detected
SBC15 00: No single-bit correction event on Memory 15 detected
NCE15 00: No non-correctable error event on Memory 15 detected
SR2 00000000 SBC16 00: No single-bit correction event on Memory 16 detected
NCE16 00: No non-correctable error event on Memory 16 detected
SBC17 00: No single-bit correction event on Memory 17 detected
NCE17 00: No non-correctable error event on Memory 17 detected
SBC18 00: No single-bit correction event on Memory 18 detected
NCE18 00: No non-correctable error event on Memory 18 detected
SBC19 00: No single-bit correction event on Memory 19 detected
NCE19 00: No non-correctable error event on Memory 19 detected
EAR0 00000000 EAR 00000000
SYN0 00000000 SYNDROME 00
EAR1 00000000 EAR 00000000
SYN1 00000000 SYNDROME 00
EAR2 00000000 EAR 00000000
SYN2 00000000 SYNDROME 00
EAR3 00000000 EAR 00000000
SYN3 00000000 SYNDROME 00
EAR4 00000000 EAR 00000000
SYN4 00000000 SYNDROME 00
EAR5 00000000 EAR 00000000
SYN5 00000000 SYNDROME 00
EAR6 00000000 EAR 00000000
SYN6 00000000 SYNDROME 00
EAR7 00000000 EAR 00000000
SYN7 00000000 SYNDROME 00
EAR8 00000000 EAR 00000000
SYN8 00000000 SYNDROME 00
EAR9 00000000 EAR 00000000
SYN9 00000000 SYNDROME 00
EAR10 00000000 EAR 00000000
SYN10 00000000 SYNDROME 00
EAR11 00000000 EAR 00000000
SYN11 00000000 SYNDROME 00
EAR12 00000000 EAR 00000000
SYN12 00000000 SYNDROME 00
EAR13 00000000 EAR 00000000
SYN13 00000000 SYNDROME 00
EAR14 00000000 EAR 00000000
SYN14 00000000 SYNDROME 00
EAR15 00000000 EAR 00000000
SYN15 00000000 SYNDROME 00
EAR16 00000000 EAR 00000000
SYN16 00000000 SYNDROME 00
EAR17 00000000 EAR 00000000
SYN17 00000000 SYNDROME 00
EAR18 00000000 EAR 00000000
SYN18 00000000 SYNDROME 00
EAR19 00000000 EAR 00000000
SYN19 00000000 SYNDROME 00
AFTER
Core Registers
R7 11111111 R15 0 R23 0 R31 1
TBU F0D20C0C USPRG03F8F507F CTR 4004189E IP 0083DF40
SPRG7 F8A9D1F6
SR1 00000080 SBC8 00: No single-bit correction event on Memory 8 detected
SBC14 01: Single-bit correction event on Memory 14 detected
EAR14 40040790 EAR 40040790
SYN14 46000000 SYNDROME 46
davidtosenovjan PetrS  Please help
Thank You
Tags (4)
petervlna
I have just downloaded and tested Davids code and it is reporting in ERM after 1-bit error is injected as expected.
See my screenshot bellow:
I did no modification to it, just run it.
regards,
Peter
ignatiusmichael
Hi Peter,
Thanks for you speedy reply. Even i am able to get SBC14 01: Single-bit correction event on Memory 14 detected as shown in the log file above but in my case IVOR1 exception is not being raised and machine_Check_Handler is not being called. i have even attatched my core registers log for your reference. my
 MSR 02008000
Please help how can i get my IVOR1 handler to work i am using the same startup files as given in the example project.
Thank you,
Michael Jihan
petervlna
That's correct.
Single bit will not cause exception. As the single bit event is automatically repaired by ECC machine.
However multibit ECC will cause IVOR1.
For multibit you have to enable it in example code.
regards,
Peter
