Flash Programming error
samyukta_s
I am working on a Board which has MPC8360 Power PC. I am not able to program the flash which is interfaced to the Power PC. When monitored the LWE (write enable) signal we are getting high, where as in other working boards its pulsing. May i know how to rectify this?
Samyukta
ufedor
1) Was the board checked for a manufacturing/soldering issue?
2) Is the flash chip-select pulsed?
3) Is the LWE probed directly on the processor's pin?
samyukta_s
Dear Sir,
Yes, its checked.
yes , its pulsing. We have replaced the board with new flash IC.
The processor pin is interfaced with a resistor(33 ohm) to the flash. We probed at the resistor end.
ufedor
4) Please use a debugger, execute write operation to the Flash LBC memory bank (chip-select) and check the LWE0 behaviour.
samyukta_s
Dear Sir,
We checked it LWE0 is always high, whereas in other working boards its pulsing.
Thanks & Regards,
Samyukta Sudheendra
E-1181
Systems Engineer
Communications (Radio Relay)
ALPHA DESIGN TECHNOLOGIES PVT LTD
No. 271, 6th Main, Defence Colony 100ft Road, Indira Nagar, Bangalore - 560 038, India
Tel: +91-80-4255 6506| Fax: +91-80-4255 6523| Mob: +91 9901782861| Email: samyukta.s@adtl.co.in<mailto:amitmishra@adtl.co.in>
ufedor
Please use a debugger to ensure that settings of LBC registers are identical on operational and problem boards.
If the LBC settings are identical, please perform the ABA swap - i.e. interchange processors between operational and problem boards.
samyukta_s
Dear Sir,
The LBC registers are identical for operational and problem boards.
With Regards,
Samyukta
ufedor
Please perform the ABA swap - i.e. interchange processors between operational and problem boards.
samyukta_s
Dear Sir,
We have replaced the processor with new IC. Even after the replacement, there is no improvement.
Please guide.
With Regards,
Samyukta
ufedor
Please check that RCW is supplied correctly and is the same as on operational boards.
What are measured levels when the resistor is removed?
