Reference voltage change from 2.5V to 5V using LTC2442
alphy
I am using LTC2442 24-bit ADC for one of my project. I am using it in single mode.The maximum input voltage measured is only 2.5V. If I am giving input voltage above 2.5V the output read is 2.5V and it is not changing. Is there any command to change reference voltage from 2.5V to 5V.
Please let me know is there any command for setting reference voltage from 2.5V to 5V.
Thank you,
Alphy
