CLRC663用I2C无法读取寄存器
CLRC663用I2C无法读取寄存器
joycn01
我用SPI和UART调试均OK;
但是我用I2C时,就不行了。
有应答,但是读取寄存器时总是0
导致无法正常读卡,波形如下。
麻烦帮忙看看,谢谢。
Kan_Li
Hello Paul,
Would you please specify which registers you are trying to read from CLRC663? I may help to check the timing.
Thanks for your patience!
Kan
