JN5169 JN-AN-1201how to send data
fangliang2316
 I'm developing a door sensor,a sleeping device.
 I'm working with JN-SW-4168 SDK  and JN5169.    I'm using a JN-AN-1201 ZigBee Intruder Alarm System application note as a base for my application.
when zone status changes,app_vUpdateZoneStatusAttribute()  is called.
app_vUpdateZoneStatusAttribute (
ZONE_ZONE_ENDPOINT, /*uint8 u8SourceEndPoint,*/
CLD_IASZONE_STATUS_MASK_ALARM1,/*uint16 u16StatusBitMask,*/
CLD_IASZONE_STATUS_MASK_SET /*bool_t bStatusState);*/
 But I don't know how the data is sent.How to know whether the data transmission is successful or failed, and how to control the number of data retransmissions if the transmission fails.
mario_castaneda
Hi Liang,
Please look at the table parameter u16StatusBitMask. You will see the mask enumeration.
eCLD_IASZoneUpdateZoneStatus ZigBee Cluster Library User Guide.
Mario
